• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    gperego
    Re: River Analysis Extension for AutoCAD Civil 3D / AutoCAD Map 3D
    01-05-2012 01:34 AM in reply to: wfberry
    Hi all,
    Thanks Bill for your suggest, but in my Start-All menu I haven't any icon for RAE.
    I rebuilt it manually with this from the Civil 3D one with this destination:
    "C:\Program Files\Autodesk\AutoCAD Civil 3D 2012\acad.exe" /ld "C:\Program Files\Autodesk\AutoCAD Civil 3D 2012\AecBase.dbx" /p "<<C3D_Italy>>"
    And especially from:
    "C:\Program Files\Autodesk\Project River Analysis 2012"
    I found also the Icon, in the RAE folder.
    The link for myGIS&INfrastructure  Blog is:
    www.bimacademy.it/gis
    You can read it using Google Translate.
    Regards
    Many thanks!
    Giovanni from Tech Data Italy
    Please use plain text.
    Distinguished Contributor
    02-08-2012 12:52 PM in reply to: gperego
    Finally recieved some HEC/RAS info to try out in the program!!! All seemed to be working well until I tried to "Compute Analysis"
    I was able to Import the HEC/RAS project. It seemed to draw all the components (reach, profiles, cross sections) All the section had data that matched the rersults in HEC/RAS etc... but when I clicked on "Compute Analysis" it gives the error message:
    Run-time error '429':
    Active X Component can't create object
    Any help would be appreciated.
    Edit: This is being done with Civil 3d 2012 (32bit) and Windows XP if it matters.
    Civil 3D 2012
    Windows 7 Pro (64bit)
    Intel Xeon W5580 @3.20GHz
    12gig RAM
    NVIDIA Quadro 600
    *Expert Elite*
    02-09-2012 06:49 AM in reply to: mjung
    I believe the current River Analysis 2012 is for 64 Bit Civil 3D 2012 or 64 Bit Map 3D 2012.
    Bill
    02-09-2012 07:01 AM in reply to: gperego
    Thanks for the reply. I was going over the install and remembered that one of the files failed to register. So that could also be the issue.
    I tried the Retry multiple times but finally hit the ignore. I wonder if there is a way to manually register this file? If not it looks like a re-install might be coming...
    Civil 3D 2012
    12gig RAM
    NVIDIA Quadro 600
    Employee
    Matt.Anderson
    02-09-2012 07:29 AM in reply to: mjung
    What operating system did you install on?
    Did you turn OFF User Account Control to install?
    Matthew Anderson, PE
    Business Consultant
    Global Services
    Autodesk, Inc.
    02-09-2012 07:35 AM in reply to: Matt.Anderson
    This was on Windows XP so the "User Account Control" isn't applicable. I do have full admin privileges on the account.
    Civil 3D 2012
    12gig RAM
    NVIDIA Quadro 600
    *Expert Elite*
    johnm
    02-21-2012 07:22 AM in reply to: mjung
    I played around with this last week and hit a brick wall with an 'Error Loading Geometry File' (from HEC Ras) when I ran the computation.
    The app really needs to work with C3D objects (alg, profiles and sections).
    The app did not like 2d or 3d polylines for a 2 stage weir I had to model.
    Overalll I loved the product and the workflow.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    hng
    New Member
    hng
    02-24-2012 12:27 PM in reply to: mjung
    I have the same issue. I was able to import XS from Hac Ras, however when I run it, I see the same error message, can somebody tell me what to do? Thanks!
    (my system info
     Intel Xron Processor 3.07 GHZ
    Winow 7 64-bit
    Nvidia Quadro 2000)
    When I start the program, I will see this mesage
    Member
    fadi_k
    02-24-2012 10:34 PM in reply to: scott.sheppard
    is there a tutorial out there for this?
    thanks
    BHFH
    02-25-2012 01:43 AM in reply to: hng
    @hng: try starting as administrator. I think river analysis is trying to create files in UAC protected area.
