• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Employee
    Matt.Anderson
    Re: River Analysis Extension for AutoCAD Civil 3D / AutoCAD Map 3D
    06-14-2012 04:54 AM in reply to: johnm
    Yes, River Analysis can read in the HEC-RAS project file and then can load the results for floodplain mapping.
    Matthew Anderson, PE
    Business Consultant
    Global Services
    Autodesk, Inc.
    Please use plain text.
    06-14-2012 05:01 PM in reply to: scott.sheppard
    Thanks Mathew,
    OK I think I have found that option now for writing out the floodplain lines. Ta.
    Regards
    Dean Petersen
    Valued Contributor
    07-19-2012 04:35 PM in reply to: scott.sheppard
    Any News on a version for 2013?
    Paul
    Paul R. Mascaro
    CAD Supervisor | Engineering Design
    ENVIRON International Corporation
    System: Dell 6600M
    OS | MS Windows 7 64-bit SP1
    CPU | Intel Core i7 @ 2.70GHz
    RAM | 8.00 GB DDR3 1600 MHz (Dual-Channel @ 798MHz)
    Graphics | NVIDIA Quadro 5010M (4 Gig)
    Valued Mentor
    fcernst
    09-18-2012 03:15 PM in reply to: scott.sheppard
    Does this work with C3D 2012 SP2.1 ?
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
    Active Contributor
    subsales
    09-19-2012 07:33 PM in reply to: fcernst
    Fred;
    Yes, River Analysis works with latest the AutoCAD Civil 3D 2012 service pack.
    Did you encounter this error when opening a prior drawing or just on launch.
    Valued Mentor
    fcernst
    09-19-2012 07:54 PM in reply to: subsales
    On launch. Sent from my iPhone
    Ernst Engineering
    Fred Ernst, PE
    Employee
    Matt.Anderson
    09-21-2012 08:05 AM in reply to: Matt.Anderson
    Fred -
    I would suggest uninstalling and reinstalling River Analysis, but it launches, and imports without issue on SP2.1.
    Business Consultant
    Global Services
    Autodesk, Inc.
    Valued Mentor
    fcernst
    09-21-2012 08:47 AM in reply to: Matt.Anderson
    Matt,
    I did that before my first message, and just reinstalled again this morning and still get the "unexpected error quitting" message. I am also getting this message when closing the program.
    Ernst Engineering
    Fred Ernst, PE
    Employee
    Matt.Anderson
    09-21-2012 09:07 AM in reply to: fcernst
    I assume you had it working prior to SP2.1?  The first download of extension expired in December, and the latest version extended that original date.  I assume you have the latest download.
    For installation, check prior posts to verify that the files are copied correctly and your River Analysis icon has the necessary Administrative privileges.
    As for the last error, its a bit difficult to tell what didn't close prior to AutoCAD Civil 3D closing. Its a benign error.
    Business Consultant
    Global Services
    Autodesk, Inc.
    Valued Mentor
    fcernst
    09-21-2012 09:28 AM in reply to: Matt.Anderson
    I just right-clicked on the imperial icon now and ran as administrator as you suggested and it launched without that error.
    Yes I did have it running before.
    Thanks for the help Matt.
    Fred
    Ernst Engineering
    Fred Ernst, PE
