• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Revise Stationing
    111 Views, 4 Replies
    12-10-2012 10:54 AM
    How do I revise the profile stationing from 100+00 to display 100.
    Also is it possible to remove the begining and end stations in the profile view
    I have attached an example
    Rick
    Please use plain text.
    *Expert Elite*
    Re: Revise Stationing
    12-10-2012 11:11 AM in reply to: rcallison
    It's all in the styles:
    *Expert Elite*
    Edit your Pofile View Style.
    go to the Horizontal Axes Tab, where it says Tick label text click on the edit button on the right (with an 'A' on it)
    Hightlight the text that is there, and look at the options on the left.
    At the bottom (in my version anyway) is the 'Output'
    Switch this to say 'left of station character' and then click on the arrow at the top to replace the text with the change you made.
    Click Ok, Ok.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    *Expert Elite*
    12-10-2012 11:14 AM in reply to: rcallison
    Also in the Horizontal Axes Tab I see the option to tick and label start station.  I don't see an option for the end station though.
    *Expert Elite*
    12-10-2012 11:32 AM in reply to: rcallison
    And to turn off the start/end station label, turn off the bottom axis labels and use a Band to label the stations instead. You can then determine to use the start/end stationing.
