• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    djocwf54
    Reverse feature per layout???
    120 Views, 8 Replies
    02-22-2012 07:42 AM
    Can you reverse a feature per layout
    I have some sewer lines in a layout that are upside down ( we do have 6"ss in the line)
    but if I reversefeature them it will make them upside down in the next layout
    thanks have a great day
                            dj
    *Pro
    Re: Reverse feature per layout???
    02-22-2012 07:51 AM in reply to: djocwf54
    Do you know about Dview Twist? Is there a reason you can't just use that function?
    Tim Corey
    Delta Engineering Systems
    Redding, CA
    Valued Contributor
    djocwf54
    02-22-2012 08:12 AM in reply to: tcorey
    never used it will look into it thanks
    Valued Contributor
    djocwf54
    02-22-2012 08:23 AM in reply to: tcorey
    I tired dview twist but that seemed to do the same thing as mviewsetup
    I need to reverse a sewer line differently in different layouts
    not the whole view just one line
    IM new to dview twist I might not have done it correctly
    thanks
                                 dj
    Distinguished Mentor
    02-22-2012 08:32 AM in reply to: djocwf54
    I may be wrong but it sounds like the problem you are having is a linetype issue. Linetypes with text in the definition will not dynamically orient to a view so DVIEW TWIST will not help. There are no easy solutions if the line is inverted in some views but not others. Generally we have to live with upside down text in some cases unless someone insists on having it right in all views. In that case you'll have to blow some of your budget to make them happy.
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    Valued Contributor
    djocwf54
    02-22-2012 08:40 AM in reply to: Neilw
    Thanks I will stop searching for an answer
    maybe this is something to post on the wishes list
    have a most awesome day
                                            dj
    02-22-2012 08:45 AM in reply to: djocwf54
    Will this work, as a workaround?  Create a copy of the line and put it on a new layer.  Then reverse the copied line.  Then you can turn layers on of off in each viewport based on the orientation needed.
    Valued Contributor
    djocwf54
    02-22-2012 09:28 AM in reply to: nvengineer
    that will work thanks
    i also put this request in the wishes
    thanks so much for your help
                            dj
    02-24-2012 03:39 AM in reply to: djocwf54
    I was going to suggest looking into the upright linestyle as this keeps any text components in a line type upright as the line changes direction, but I just tried it out in rotated viewports and it does not work unfortunately.
    This applies to both autocad lines and polylines as well as civil 3d pipe styles.
    Andrew Puller
    Maitland, NSW, Australia
    Windows 7 Enterprise 64bit
    Intel core i7 2600 @ 3.40 GHz with 16GB Ram
    Civil 3d 2011 & 2012 64bit
