• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Reverse alignment direction
    3833 Views, 10 Replies
    08-15-2010 11:55 PM
    Can I reverse the direction of an existing horizontal alignment line in C3d 2011?
    Please use plain text.
    Valued Mentor
    Re: Reverse alignment direction
    08-16-2010 03:04 AM in reply to: WERNERSMITH1201
    Try typing
    AeccReverseAlignDirection
    at the command line. It use to be in the alignment menu not sure where it is on ribbon.
    Regards
    Justin Ralston
    Regards
    Justin Ralston
    http://c3dxtreme.blogspot.com/
    Valued Mentor
    08-16-2010 04:19 AM in reply to: WERNERSMITH1201
    On the ribbon just click on the alignment you want to change and the Alignment tools tab appears, from that click Modify > Reverse Direction.269i3BF8484650E428C7
    Mike Robertson
    FL. Dept. of Transportation
    CADD Applications Developer
    HPxw4600 Workstation
    Core 2 Duo 2.33ghz, 8gb RAM
    nVidia Quadro FX1700
    Win7 64bit
    Active Member
    08-16-2010 05:55 AM in reply to: WERNERSMITH1201
    It does not get easier than that!!
    Thank you very much for the help
    Valued Mentor
    08-16-2010 05:58 AM in reply to: WERNERSMITH1201
    Your welcome, the ribbon in 2011 is much better than before.
    Mike Robertson
    Win7 64bit
    Distinguished Contributor
    04-18-2011 12:55 PM in reply to: michael.robertson
    Just reversed an alignment using this tool, worked great.
    My questions is, design profiles created 'by layout' do not update using the alignment reverse tool? Makes sense, but there doesn't appear to be a reverse tool on the ribbon when a profile is selected like there is for an alignment as you show in your screen capture. Do you know of a way to reverse a profile or have any other suggestions?
    Thank you.
    Valued Mentor
    04-18-2011 02:23 PM in reply to: WERNERSMITH1201
    To revserse the profile I have in the past copied the profile geometry from the geometry editor into Excel subtracted
    the total chaninage off the wrong chainage and time by -1. Then from excel exported a profile txt file in the format
    described in the Civil3d  help under "Format Requirements of Profile Files" and imported it back into civil3d. There maybe a better way now that some one knows but this got the job done for me.
    Regards
    Justin Ralston
    Regards
    Justin Ralston
    afunian
    04-19-2011 12:40 PM in reply to: WERNERSMITH1201
    It is very simple.
    on drawing aria jast click on alignment you want to reverse it.
    on the lower middle of ribbon clicl on MODIFY.
    Then click reverse direction.
    New Member
    meera24
    02-09-2012 02:59 AM in reply to: WERNERSMITH1201
    I tried reversing but the alignment just does not reverse for some reason
    03-05-2013 10:33 AM in reply to: WERNERSMITH1201
    I got mine reversed but it put my station numbers on top of the alignment. How do I bring it back under the alognment?
