• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    abetts
    Reverse a linetype
    248 Views, 10 Replies
    12-17-2012 12:14 PM
    I have a polyline in my drawing, consisting of arcs and lines all joined together. It is a waterline and I cannot get it to reverse.. it is reading ----M----- instead of -----W-----
    Please use plain text.
    *Expert Elite*
    Re: Reverse a linetype
    12-17-2012 12:32 PM in reply to: abetts
    Perhaps your linetype definition uses a U value for angle, so the text remains upright (to the U value, so 180 would make it upside down) no matter how the object is rotated. Take a look at the linetype file and see if this could be your issue.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    *Expert Elite*
    12-17-2012 01:31 PM in reply to: abetts
    How are you trying to reverse it?
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    *Expert Elite*
    12-17-2012 02:14 PM in reply to: mathewk
    Matt, I assume he used the Reverse command. That doesn't work on U-coded linetypes.
    Tim Corey, Owner
    Redding, CA
    *Expert Elite*
    rkmcswain
    12-17-2012 02:30 PM in reply to: abetts
    Its possible that the OP does not have the .LIN file.
    In that case, you could use TO-LIN.LSP to extract the linetype definition to a file for inspection.
    http://www.turvill.com/t2/free_stuff/to-lin.lsp
    *Expert Elite*
    12-17-2012 05:46 PM in reply to: abetts
    Tim, indeed, I'm just covering the hopefully obvious.
    OP, there is a REALLY annoying problem with the feature Tim spoke of. If your view is not North up could have a situation where no linetypes are upright.
    I avoid them and create a copy of the linetype where the text is rotated 180 degrees.
    Matt Kolberg
    abetts
    12-19-2012 10:35 AM in reply to: abetts
    The solution to this ended up being simple. Once selecting the line, in the bottom of the properties box there is an option for "Linetype Generation", it was disabled. Once enabling, all was fixed.
    Thank for the suggestion guys!
    *Expert Elite*
    12-19-2012 02:25 PM in reply to: abetts
    Boy do I feel dumb for not getting that one! I knew that contolled where the patterns fall, but I had no idea it would affect the rotation of the lettering. So, in your linetype, you're using U coding for angle, plus Linetype Generation turned on?
    Tim
    Tim Corey, Owner
    Redding, CA
    abetts
    01-15-2013 06:07 PM in reply to: tcorey
    I'm a girl. :smileyhappy: Aubrey Betts CAD Technician Lennon, Smith, Souleret Engineering, Inc. 846 Fourth Avenue, Coraopolis, PA 15108 (412) 264-4400 Ext. 205 www.lsse.com
    abetts
    It seems so. I didn't know this either but whatever works I suppose! Aubrey Betts CAD Technician Lennon, Smith, Souleret Engineering, Inc. 846 Fourth Avenue, Coraopolis, PA 15108 (412) 264-4400 Ext. 205 www.lsse.com
