AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Reverse a linetype
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have a polyline in my drawing, consisting of arcs and lines all joined together. It is a waterline and I cannot get it to reverse.. it is reading ----M----- instead of -----W-----
Re: Reverse a linetype
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Perhaps your linetype definition uses a U value for angle, so the text remains upright (to the U value, so 180 would make it upside down) no matter how the object is rotated. Take a look at the linetype file and see if this could be your issue.
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
How are you trying to reverse it?
Cansel - Autodesk Division
http://www.cansel.ca/
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Matt, I assume he used the Reverse command. That doesn't work on U-coded linetypes.
Redding, CA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Its possible that the OP does not have the .LIN file.
In that case, you could use TO-LIN.LSP to extract the linetype definition to a file for inspection.
http://www.turvill.com/t2/free_stuff/to-lin.lsp
R.K. McSwain
CADpanacea.com | twitter | Cadalyst Tips
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
OP, there is a REALLY annoying problem with the feature Tim spoke of. If your view is not North up could have a situation where no linetypes are upright.
I avoid them and create a copy of the linetype where the text is rotated 180 degrees.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The solution to this ended up being simple. Once selecting the line, in the bottom of the properties box there is an option for "Linetype Generation", it was disabled. Once enabling, all was fixed.
Thank for the suggestion guys!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Boy do I feel dumb for not getting that one! I knew that contolled where the patterns fall, but I had no idea it would affect the rotation of the lettering. So, in your linetype, you're using U coding for angle, plus Linetype Generation turned on?
Tim
Redding, CA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
