• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    AllenJessup
    Accepted Solution
    Reverse OSnapZ
    153 Views, 3 Replies
    03-12-2012 08:03 AM
    I don't want to disable OSnapZ. What I'd like to do is to find a way that would prevent the automatic picking of 0 elevation when there are 2 endpoints, or other osnap points, that are coincident in the X,Y but have different Z values. One of the Z's being 0.
    I get a lot of work in 2D and have to do the grading. I'm always having to switch off the proposed 2D layer to be able to pick the 3D end of a Polyline or a Featureline.
    Allen
    Please use plain text.
    *Expert Elite*
    johnm
    Re: Reverse OSnapZ
    03-12-2012 08:36 AM in reply to: AllenJessup
    When promted to select the point in question with overlapping lines, I hit the tab key (or shift + Space) to cycle through the objects. When I see the object I want to snap to highlighted I select the point. Works fairly well. The AutoCAD Selection Cycling (CTL + W) also works but it slows my pc.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    *Expert Elite*
    AllenJessup
    Re: Reverse OSnapZ
    03-12-2012 08:45 AM in reply to: johnm
    Good one John!
    I didn't think it was working. But I have selection preview on. So I had to get a little off the line I wanted in order to see the selection changing.
    Allen
    *Expert Elite*
    johnm
    Re: Reverse OSnapZ
    03-12-2012 09:03 AM in reply to: AllenJessup
    Glad to help Allen. I have been picking up unwanted zeros for quite some time now. :smileyhappy:
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
