• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Retaining walls- Please help
    635 Views, 6 Replies
    04-27-2012 06:00 AM
    hi everyone,
    can anyone told me where is my mistake in making the retaining wall?
    i attached here the screenshoots.
    this retaining wall is made using a subassembly not using feature line.
    Please use plain text.
    *Expert Elite*
    Re: Retaining walls- Please help
    04-27-2012 06:02 AM in reply to: MK2012
    Not sure what the problem is, can you describe what you are expecting vs what is shown in the image?
    Jeff_M, also a frequent Swamper
    Valued Mentor
    owenmull
    04-27-2012 07:40 AM in reply to: MK2012
    As Jeff said, I'm not totally sure what the problem is. Looks fine to me. Could you post another image, perhaps detailing exactly what your retaining wall is/isnt doing correctly?
    -Owen
    Windows 7 x 64 bit
    ATI FirePro V4800 Triple Monitor
    12 GB RAM
    Intel Xeon W3550 @ 3.07 GHz
    Civil 3D 2012 SP 2
    ______________________________________________________________
    Intel inside. Idiot outside.
    Usually, I find that the problem is between the keyboard and the chair.
    *Expert Elite*
    04-28-2012 05:41 AM in reply to: owenmull
    I'm guessing that he wanted the vertical face to be exposed.
    Bill
    Member
    04-30-2012 01:20 AM in reply to: MK2012
    hi all,
    i made the road corridor using a basic assembly but when i added the retaining wall subassembly the wall shown in the realistic view as sections not as a real wall.
    the codes are applied in the code style as shown in the screenshoots.
    Valued Mentor
    owenmull
    04-30-2012 08:42 AM in reply to: MK2012
    You've got your links coded, what about your shapes? Are they coded correctly, and set to display?
    -Owen
    Windows 7 x 64 bit
    12 GB RAM
    Civil 3D 2012 SP 2
    Member
    05-03-2012 01:51 AM in reply to: MK2012
    Can anyone attach a DWG file of a subdivision of lots including building retaining walls?
    I need to compare the codes and parameters with those i used.
