• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    kevinsbane
    Re: Renumbering Points
    09-20-2012 08:04 AM in reply to: Jeff_M
    I've been using this command for a while now (thank you again to Jeff!) but now that I've upgraded to Civil 3D 2013, I'm getting an error;
    "; error: bad argument type: stringp nil"
    Any help would be appreciated.
    Please use plain text.
    *Expert Elite*
    09-20-2012 08:45 AM in reply to: kevinsbane
    Open the lisp file using either Notepad or the VLIDE inside C3D. Find the section of code that looks similar to this, then make it look exactly like this (add a few lines so it finds C3D2013).
    (setq	verstr (cond ((vl-string-search "\\R18.0\\" prod)
    		      "7.0"
    		     ;;2010
    		     ((vl-string-search "\\R18.1\\" prod)
    		      "8.0"
    		     ;;2011
    		     ((vl-string-search "\\R18.2\\" prod)
    		      "9.0"
    		     ;;2012
    		     ((vl-string-search "\\R19.0\\" prod)
    		      "10.0"
    		     ;;2013
     Save it then reload.
    kevinsbane
    09-25-2012 11:59 AM in reply to: kevinsbane
    Jeff, I've modified the lsp as per your instructions, and am now getting the following error:
    ; error: "no applicable method for:" (QueryInterface nil)
    *Expert Elite*
    09-25-2012 01:06 PM in reply to: kevinsbane
    Kevin, which version of the lisp have you been using, the original I posted or the one modified by Gavin?
    Attached is Gavin's version updated to work in 2013.
    kevinsbane
    09-27-2012 03:21 PM in reply to: Jeff_M
    My thanks. I had been using yours, but this one works well.
