• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    Garvess
    Rendering grades problem
    162 Views, 4 Replies
    07-24-2011 10:52 PM
    Ive been using civil 3d to design a subdivision and I'm doing the grades for the lots now. The grading tools are working fine but my problem is that whenever the drawing is viewed in 3d realistic the surface is still spilling on top of my lots. The surface doesn't seem to be changed by the cut and fill being applied. Could anybody give me any clues as to how I could fix this?
    Please use plain text.
    cdavenport
    Re: Rendering grades problem
    07-25-2011 06:23 AM in reply to: Garvess
    How are the lot grades being put into "the surface".
    Cyndy Davenport
    Bowman Consulting Group
    cdavenport@bowmancg.com
    c3dcougar.typepad.com
    Civil 3D 2014
    Windows 7 - 64 bit
    32GB RAM
    Intel Core i7-2860QM CPU @ 2.50GHz
    NVidia Quadro 2000M
    07-25-2011 07:25 AM in reply to: Garvess
    Your posting is a little vague. Do you mean that your EG surface is spilling over your FG surface in areas of cut when viewing both surfaces in 3D? If so, it will do that as in 3D it shows the higher of the two surfaces on top regardless of what you have designed for the FG.
    Eric Collins, P.Tech.(Eng.)
    Win 7 Pro SP1 64 bit
    Intel i7 3770 @ 3.40 GHz
    16 GB RAM
    Civil 3D 2014 (IDSP)
    New Member
    Garvess
    07-25-2011 08:21 AM in reply to: ericcollins6932
    Yeah my existing ground is spilling onto my road corridor and lots when I visualize it in 3d. It just seemed to me like there must be a way to may a way to fix it because I've seen so many civil 3d drawings online that look great in 3d with no issues like that.
    07-25-2011 08:24 AM in reply to: Garvess
    I would suggest copying your EG and pasting your FG into it - which will give you a composite surface for viewing purposes.
    16 GB RAM
