• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    hb
    Active Member
    Removing item from selection set causes fatal error in 2013
    260 Views, 7 Replies
    04-19-2012 11:53 AM
    Hey all,
    Has anyone else experienced this.  I go to erase a line or a piece of text or block, doesn't seem to matter really.  Anyways I select one too many items so I hit "r" for remove and select the item to remove and bam, I fatal error, civil 3D shuts down, asks if I'd like to save the file and then also submits an error report to the great unknown.
    Any thoughts on how to cure this?
    Civil 3D 2013, on 64 bit Windows 7 with all updates.
    Heidi B.
    Please use plain text.
    Re: Removing item from selection set causes fatal error in 2013
    04-20-2012 05:23 AM in reply to: hb
    When you are finished selecting items to erase move the cursor away from any selected items, then use the DELETE key to erase.
    Bill
    hb
    Active Member
    04-20-2012 06:02 AM in reply to: wfberry
    Bill,
    Great idea.  One problem though the minute i select the item, after I've told it to remove selected items, it fatal errors, I don't get a chance to move the cursor away.  But if I could I would trust me. Any other thoughts on this?
    Heidi B.
    04-20-2012 06:17 AM in reply to: hb
    I don't have this problem, perhaps you need to do a repair of your installation.   Takes about 5 minutes.
    Bill
    (Do a Google search if necessary)
    Member
    bachrist
    08-02-2012 10:03 AM in reply to: hb
    Having the same problem on multiple workstations with a fatal error after using "R" or "shift" to remove an entity from a selection set.
    Was there a solution determined for this problem?....
    hb
    Active Member
    08-03-2012 05:38 AM in reply to: hb
    Nope, never found a solution, still does it to this day even after all the hotfixes. Sincerely, Heidi Boutwell Sr. Civil Designer [Description: cid:image001.jpg@01CC0665.75220890] 1015 N. Broadway Ave, Suite 300 Oklahoma City, OK 73102 Phone (405) 842.1066 ext. 233 Fax (405) 843.4687 Iphone (360) 870.3218 hb@cardinalengineers.com
    Employee
    hgohel
    08-03-2012 02:35 PM in reply to: hb
    This is defect 1460720 that we are are actively working on.
    Himanshu Gohel
    Autodesk, Inc
    Employee
    hgohel
    08-29-2012 12:27 PM in reply to: hb
    Please install Hotfix 2 for Civil 3D 2013 for a resolution to defect 1460720.
    Himanshu Gohel
    Autodesk, Inc
