• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Joe Bouza
    Re: Removing .dst from Recent Documents list
    10-28-2009 05:18 AM in reply to: mjung
    Why is this beneficial?
    Thanks, Joe
    Please use plain text.
    Distinguished Contributor
    10-28-2009 08:02 AM in reply to: mjung
    If AutoCAD used this list as a true recent file list this wouldn't be helpful. But it doesn't. Every time you open the program it forces just the sheet sets to the top of the list, even they haven't been used for months. Most of our Civil 3D design files are not a part of a sheet set, they are just a dwg file. After working on 25+ projects the list of sheet sets (dst) becomes quite long and you have to scroll down to the dwg files. And if your old-school and use the File pull-down (2009) they're not even on that list after opening 9 sheet sets. (gotta stop using that so I'm prepared for 2010)
    If a project is finished and no longer necessary to have in the list it's going to be there for a long time. (maybe that's a good thing) but I like to get to my recent dwg files quickly.
    Civil 3D 2012
    Windows 7 Pro (64bit)
    Intel Xeon W5580 @3.20GHz
    12gig RAM
    NVIDIA Quadro 600
    *Joe Bouza
    10-28-2009 10:33 AM in reply to: mjung
    Im still on 2008 and my recent file list only contains DWG files (I guess I
    luked out)
    *Expert Elite*
    10-28-2009 11:46 AM in reply to: mjung
    I think this problem was introduced in 2009.
    The STARTUP dialog is also a mess. I keep using it (with STARTUP=1), because I find it less annoying that constantly closing that useless "Drawing1.dwg" that C3D creates at startup if STARTUP=0. But the drawings in the Startup Dialog list in an apparently random order, with DST files mixed in, drastically impacting the usefulness of this feature. And the dialog box can't remember column widths between invocations, so I constantly have to stretch out the filename column so I can read my filenames. Still, I find it to be the less-annoying option, so I leave STARTUP=1.
    -- Sinc
    http://www.ejsurveying.com
    http://www.quuxsoft.com
    Sinc
    *Jeff Mishler
    10-30-2009 08:51 AM in reply to: mjung
    OK, I'll admit that I may be needing glasses in my advancing age, but I sure
    don't see the DST files being listed anywhere in the FixedProfile.aws in
    2009 or 2010. Can you point me to where these files are stored, and where in
    the files I can find the data?
    "mjung" wrote in message news:6279188@discussion.autodesk.com...
    > I see that this topic hasn't been addressed for a while. I thought I'd
    > share my workaround for anyone interested.
    > Using XML Notepad 2007 (google it. It's a free download) you can edit the
    > FixedProfile.aws to remove the dst files listed in the recent files.
    > Just open the file. Use the Find to search for .dst. Then delete the
    > MRU_FILE sections you don't want.
    > The list will grow again as you work, but at least the older dst listings
    > will be gone. And this only removes the dst's, all your dwg files will
    > still be there.
    > Hope this helps...
    10-30-2009 09:25 AM in reply to: mjung
    On our systems (XP) they are located in:
    C:\Documents and Settings\username\Application Data\Autodesk\C3D 2009\enu\Support\Profiles\FixedProfile.aws
    C:\Documents and Settings\username\Application Data\Autodesk\C3D 2010\enu\Support\Profiles\FixedProfile.aws
    As far as the location in the file use the "Find" feature of the program you are using to edit.
    In XML Notepad it's in the "Edit" pulldown menu.
    See attached screenshot Edited by: mjung on Oct 30, 2009 9:26 AM
    Civil 3D 2012
    12gig RAM
    NVIDIA Quadro 600
    *Jeff Mishler
    10-30-2009 09:38 AM in reply to: mjung
    OK, Thanks! I was able to locate them now in 2009. However, 2010 does not
    store much of anything in that AWS file so I'm back to searching for where
    this info is kept. Found them! In 2010 these are now stored in the
    individual Profile.aws files for each Acad profile.
    Thanks again!
    "mjung" wrote in message news:6281270@discussion.autodesk.com...
    > On our systems (XP) they are located in: C:\Documents and
    > 2009\enu\Support\Profiles\FixedProfile.aws C:\Documents and
    > 2010\enu\Support\Profiles\FixedProfile.aws As far as the location in the
    > file use the "Find" feature of the program you are using to edit. In XML
    > Notepad it's in the "Edit" pulldown menu. <>
    10-30-2009 09:57 AM in reply to: mjung
    Thanks for the tip on 2010 location. I hadn't tried finding any dst's in the 2010 files because we haven't started using it much for production work.
    Sounds like typical AutoDesk to keep changing how everything works from release to release.
    Civil 3D 2012
    12gig RAM
    NVIDIA Quadro 600
    New Member
    12-02-2009 03:13 PM in reply to: mjung
    Am I wrong or can't you also clear the list under the menu browser (the big red C) -> Recent Document.
    Right click any file and select "Clear recent documents list"
    12-03-2009 06:39 AM in reply to: mjung
    Wish it was that easy. This will clear the list for the current session, but if you close the program and reopen only the drawings will be gone. All the sheet sets you've opened in the past will still be there.
    Civil 3D 2012
    12gig RAM
    NVIDIA Quadro 600
