• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    ModestasZ
    Remove georeference data
    196 Views, 6 Replies
    02-18-2012 11:28 AM
    At first hello to everyone :smileyhappy:
    and now to the problem. I have regions Georeferenced DWF File. All I need is only a small part of this region. How can I delete all geoferenced data outside my needed boudary? I used this function once few months ago, but now I dont remember it.
    Please use plain text.
    antoniovinci
    Re: Remove georeference data
    02-18-2012 12:27 PM in reply to: ModestasZ
    ..maybe _MAPTRIM command..?
    Member
    ModestasZ
    02-18-2012 12:31 PM in reply to: antoniovinci
    thank you :smileyhappy:
    you saved another few hours of looking for this comand
    02-18-2012 12:36 PM in reply to: ModestasZ
    may I ask just to make sure (and may be to learn something): you can remove entities within a DWF file using the MAPTRIM-command?
    I can only remove/trim entities within a DWG not within a DWF! How do you do that?
    - alfred -
    Alfred NESWADBA
    Joe-Bouza
    02-18-2012 03:55 PM in reply to: ModestasZ
    If I had to guess, nd I am guessing  it is more like a image/ XREF clip
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    02-19-2012 12:41 AM in reply to: Joe-Bouza
    _MAPTRIM (>>>details<<<) does geometry modifications, not comparable to CLIP or XCLIP which does not modify geometry (just defining a border where existing geometry should be hidden or visible).
    With _MAPTRIM you can really trim objects inside or outside a border. In this case the geometry get's modified and it's no trick just for visibility.
    And the thing I ask for is: _MAPTRIM only can handle (plane) AutoCAD geometry stored directly inside a DWG, it can't work on geometry in XRefs and it can't work on geometry within any other non-DWG-based files like PDF, DWF, ...
    I'm wondering now, that for this question "I have regions Georeferenced DWF File" the command _MAPTRIM does work. So I'm missing something. And as I don't like to miss such things the curiosity started working in my brain .... :smileywink:
    - alfred -
    Alfred NESWADBA
    Joe-Bouza
    02-19-2012 03:52 AM in reply to: ModestasZ
    Ihas me curious now, too.
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
