• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    Accepted Solution
    Remove .DST's from Recent Documents list
    1041 Views, 20 Replies
    07-22-2012 09:41 AM
    Attached is a zip file with a standalone program to aid in cleaning up the Recent Documents list for all flavors of AutoCAD, 2009-2013.
    It's pretty self explanatory, just be sure to run it with no sessions of AutoCAD, or vertical products, running. It should refuse to run if it sees any Acad.exe application in the running tasks list. Once the dialog opens it will show you all of the Autocad related products you have installed, select one and it will fill in the first list of recent documents. Then select a profile for that product and the second list will populate with the SSM related recent documents saved for that profile. You can then select any item from either list, if the same DST filename exists in both lists it will automatically select them both. Use the standard selection methods to select more than one (shift-click, control-click, window).
    Be sure to Unblock, if needed, the zip file before extracting the exe file. (Check the file properties)
    If you find it useful, or if you have any problems with this, please let me know at jeffm AT quuxsoft DOT com
    Jeff_M, also a frequent Swamper
    Please use plain text.
    *Expert Elite*
    rkmcswain
    Re: Remove .DST's from Recent Documents list
    07-23-2012 05:25 AM in reply to: Jeff_M
    Works as advertised. Thanks for sharing.
    Now that it's clean, I'll can keep an eye on how it adds and tracks recent dwg and dst files.
    Valued Mentor
    LisaPohlmeyer
    07-23-2012 05:39 AM in reply to: Jeff_M
    Awesome, awesome, awesome! Thank you!
    Lisa Pohlmeyer
    Williamson Co. Dept. of Infrastructure
    Intel i7 3.33Ghz, 16Gb RAM
    Nvidia Quadro 2000D
    C3D 2012 SP3, C3D 2014
    Win 7-64
    Please mark this as the solution if it resolves your issue.
    *Expert Elite*
    johnm
    07-23-2012 07:40 AM in reply to: Jeff_M
    Very nice of you Jeff. Thanks a bunch.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    *Expert Elite*
    07-24-2012 01:18 PM in reply to: Jeff_M
    I'm glad a few of you have found it useful!
    *Expert Elite*
    09-21-2012 01:55 PM in reply to: Jeff_M
    Is this just a one-time cleanup tool or does it also prevent new additions to the list?
    Thanks.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    *Expert Elite*
    09-21-2012 02:17 PM in reply to: troma
    It does not prevent them from being added. Run it as often as you like to cleanup the list(s).
    *Expert Elite*
    09-24-2012 06:57 AM in reply to: Jeff_M
    Very cool, thanks!
    *Expert Elite*
    09-24-2012 08:13 AM in reply to: Jeff_M
    Jeff, all of us who participate here are very lucky to have you around. Thanks for sharing this and for your on-going help.
    Tim
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    *Expert Elite*
    johnm
    09-24-2012 08:23 AM in reply to: tcorey
    Absolutely.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
