• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    neilyj
    Redefine Surface
    156 Views, 9 Replies
    02-17-2012 10:27 AM
    I have an existing ground built from contours but the client has now fshortcutsound a real topographical survey.
    I now need to build the existing ground using the new info.
    What is the best easy to do this so that all existing data shortcuts are maintained? I thought that erasing the surface build information and then rebuilding with the new
    info would be the best way to - am I correct?
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Please use plain text.
    *Expert Elite*
    neilyj
    Re: Redefine Surface
    02-17-2012 10:29 AM in reply to: neilyj
    Fshortcutsound should read found- not used to this swype keyboard on my galaxy
    neilyj
    *Expert Elite*
    02-17-2012 10:34 AM in reply to: neilyj
    That's what I would do.
    Jeff_M, also a frequent Swamper
    *Expert Elite*
    neilyj
    02-17-2012 10:58 AM in reply to: neilyj
    Thanks Jeff - is it a bad idea to delete the surface, create a new one of the same name and then build ??
    neilyj
    *Expert Elite*
    02-17-2012 11:06 AM in reply to: neilyj
    Yes, I would avoid deleting it and recreating. Removing the data operations is essentially doing the same thing without resetting the Surface object's handle. The only reason I would ever delete the surface to start over, would be if there were corruptions of some sort going on.
    Distinguished Contributor
    02-17-2012 11:15 AM in reply to: neilyj
    Just to elaborate, data shortcuts use the entity handle to identify the object which is being shared. This is a unique id for the object and stays even when the surface is renamed.
    However if the entity handle is not found, by default the shortcut will look for an object of the same type with the same name in the same drawing.
    Thus, you CAN delete and create a new surface with the same name but I think I would prefer to keep the surface I know is good and works and just 'redefine'.
    Hope this helps
    Josh Modglin
    Advanced Technologies Solutions Logo
    *Expert Elite*
    neilyj
    02-17-2012 11:16 AM in reply to: neilyj
    Thanks - I thought this process of incorporating the new data was going to be a bit painful but it seems like it should be quite straightforward (fingers crossed as I'm up against a deadline for it....!!!)
    neilyj
    *Expert Elite*
    neilyj
    02-18-2012 03:57 AM in reply to: neilyj
    Just tried removing definitions and rebuilding and seems to be working well. :smileyhappy: will complete on Monday.
    I'm sure that previously (in C3D 2011) I'd deleted the surface and created a new one of the same name but this ultimately caused major crashes and problems
    neilyj
    *Expert Elite*
    BrianHailey
    02-18-2012 09:16 AM in reply to: joshuamodglin
    In the data shortcut editor (found on the windows start menu I believe) you can change your data shortcuts from looking at the handle of the object to lookint to the name of the object instead. So, if you NEED to delete the object, you can repath the shortcuts to a new object with the same name if necessary.
    *Expert Elite*
    neilyj
    02-18-2012 10:33 AM in reply to: BrianHailey
    Thanks Brian - I'd forgotten about the shortcut editor
    neilyj
