AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Recovery by Alt - F4
- Highlight
- Email to a Friend
I wanted to relate something that just happened to me.
I was trying something to help a recent poster. I was editing a Surface Style and was going to change the Surface Point Display.
When I hit the ellipsis button on the right [...] the program froze. I tried all the trick I knew with no result. I wouldn't have lost much just ending the program but I'm stubborn.
What finally occurred to me was to hit Alt - F4, the keyboard combo for Close. I got to thinking that another dialog had opened behind the first one and if I could close it I might get control back. and I did.
I've duplicated this a couple of times to make sure it wasn't a fluke. I also found that I only had the problem when the Style editor was on my second screen. If I moved it to the first screen there was no problem.
Thought this might help someone some day.
Allen Jessup
Re: Recovery by Alt - F4
- Highlight
- Email to a Friend
Thanks Allen, good info.
Did you discover what the other dialog was? Was it there behind the surface style editor on the second screen?
Did you try the Alt+space M, arrow key, mouse trick to get it to 'snap' to the mouse?
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Highlight
- Email to a Friend
It wasn't exactly another dialog. It's more like a flyout palette. I don't know the exact term for it.
Alt+space M doesn't seem to work because it isn't an independent Dialog.
Allen Jessup
- Highlight
- Email to a Friend
Thought one of these tricks might have sorted out the Quick profile bug - but no luck..perhaps they'll have fixed it in 2014..![]()
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
- Highlight
- Email to a Friend
Kudos!
I've killed many a process beause of the
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
