• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    neilyj
    Recent documents list
    2092 Views, 49 Replies
    05-25-2011 05:13 AM
    My recent documents list (C3D 2011) is full of dst files - how can I reset it??
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Please use plain text.
    Product Support
    AlmasSuljevic
    Re: Recent documents list
    05-25-2011 06:38 AM in reply to: neilyj
    Hi neily,
    Can you elaborate where do yuo see that list/ Is it within Civil 3D or from Start?
    In Civil 3D Options menu>Open and Save tab there is  place where you can set number of recently opened files. If you just want to remove DST files you would have to exit out of Civil 3D, locate the DST files and delete them. While still in Civil 3D see where the location of the DST files are.
    Almas Suljevic
    Product Support Specialist
    Autodesk Global Subscription and Support
    Autodesk, Inc.
    Please click on "Accept as Solution" if post helped you resolve the issue.
    *Expert Elite*
    AllenJessup
    05-25-2011 06:51 AM in reply to: neilyj
    I'd look in C:\Users\<UserName>\AppData\Roaming\Autodesk\C3D 2011\enu\Recent and see if there were Links to the DST files that could be eliminated.
    Allen
    *Expert Elite*
    05-25-2011 07:01 AM in reply to: AlmasSuljevic
    AlmasSuljevic wrote:
    Hi neily,
    Almas, this is crazy! Seriously, you are suggesting to delete DST files? Why would anyone want to delete their SheetSet files? Yes, the recently used files fills with theh DST files which has friven everyone nuts for years. And there's no easy way to remove them (even deleting the DST files will not rmove them from the recent files list). What's worse, is that they don't roll out even after not accessing a dst for months, it will still show up as recently used, leaving just 3 or 4 spots for DWG files.
    This is a screen capture from my C3D2010 install. The first 4 MRU files listed are files that no longer exist...and I deleted them about 2 years ago, shortly after installing 2010. Many of the other files listed haven't been accessed in nearly a year. My MRU setting is 25, note that 23 of these are used by DST's, leaving just 2 for dwg's.
    Jimmy Bergmark has posted some ideas on this, but I haven't tried these on the newer versions....http://blog.jtbworld.com/2008/09/clear-sticky-sheet-sets-from-recent.html
    *Expert Elite*
    05-25-2011 07:03 AM in reply to: neilyj
    In my experience, the Recent Docs list has been broken since the 2009 release (the 2008 release was the last one where it worked correctly).
    I've seen various tips on the web for how to get rid of those .DST files, but I haven't found anything that really works.  The list of recent.DST files seems to be stored in multiple places...  I think there's something that re-adds DST files to the Recent Docs list from the Sheet Set Manager, or something like that.  I never did spend enough time on it to figure out what was going on.
    It's definitely been frustrating, having something that should be as simple as the Recent Docs list be broken for multiple releases...  I haven't checked 2012 yet to see if anything has been fixed.
    Sinc
    *Expert Elite*
    Joe-Bouza
    05-25-2011 07:04 AM in reply to: Jeff_M
    How bazaar is that... I just came to the board because I encountered the very same thing
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Product Support
    AlmasSuljevic
    05-25-2011 07:17 AM in reply to: Jeff_M
    I have seen many cases were customers wanted to remove DST files which do came back if Civil 3D is still running. So my suggestion how to remove them was in that light. I was not even sure if that is the intent. Obviously this is not the issue neilyj is having. Sorry if I confused soem of you. :smileysad:
    I found that you may manually remove the item by right-clicking on it. It is manual process but it works. See image:
    Almas Suljevic
    Autodesk, Inc.
    *Expert Elite*
    neilyj
    05-25-2011 07:20 AM in reply to: neilyj
    I'm getting exactly what Jeff_M is getting.
    I have recently been creating/testing sheet sets so I have a lot of temporary/test dst files that could be deleted without any worry. I'll take a look at the link too
    neilyj
    *Expert Elite*
    05-25-2011 07:33 AM in reply to: AlmasSuljevic
    Almas, that looks like a new feature in 2012.
    Sinc
    *Expert Elite*
    05-25-2011 07:37 AM in reply to: Sinc
    No, that looks like Window's Start menu....not the file list in C3D.
