• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Reading triangles from file
    523 Views, 4 Replies
    11-14-2011 07:49 AM
    I am running 2011 c3d on windows 7 with 15 GB of ram.
    An error message I get is "reading triangles from file" and the program locks up to where you need to do a reset on the computer. I have an existing ground surface that is data shortcut into the file I am opening when I get this error. The existing ground surface is about 5 mg in size. I'm not sure if this is causing the error. Any information or help on this appreciated.
    Please use plain text.
    Product Support
    Re: Reading triangles from file
    11-24-2011 07:16 AM in reply to: jak79
    What happens if you open the Drawing with RECOVER Command in Civil 3D?
    Does that work?
    Christian Bauer
    Product Support Specialist, Civil Engineering
    Autodesk, Inc.
    11-25-2011 07:13 AM in reply to: bauerc
    Thanks for the reply,
    Yes that removes three errors it find and then the drawing works fine.
    New Member
    justin
    11-02-2012 12:00 PM in reply to: jak79
    I am having the same issue, though with Civil 3d 2012.  I have tried recovering the drawing, but it still gives me this error.  Thoughts?
    *Expert Elite*
    antoniovinci
    11-02-2012 12:49 PM in reply to: justin
    Try to load, in an empty drawing, the damaged file as XREF, then "bind" it, save and exit: any changes?
