AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re-Import Points and Linework Issues
- Highlight
- Email to a Friend
I apologize for three issues in one post, but all are driving me nuts.
1. When I do a re-import of my points my linework appears to double up (linework over linework).
2. In my description keys I use "rr" for rail road and "rrisg" for railroad signal (no * in code), linework comes in for both even though I only have it set up for "rr". I thought without the * in code this would not happen, but still does.
3. Finally, I use the "Survey Point Properties" window to make edits to points. All seems great, but when I got back into my drawing all my work was gone? Do I need to update the database some how with the changes? I was under the assumption that by doing it the way I do the changes are saved to the database. Is it better to do the edit on the Survey Tab by right clicking on the import event and selecting "Edit Points"?
Thanks in advance for ANY help you can offer .....
Re: Re-Import Points and Linework Issues
- Highlight
- Email to a Friend
Hi dwk1204,
Do you also see doubled points? Do they have the same numbers or offset? When you edit your survey point with Survey Point Properties the updates should be automatic, but you would also get a message asking you whether you want to update your linework. In any case all these 3 issues you are posing are not reproducible on my end. So I would think that there is something wrong with one of the two things. Your survey database or your inatsllation.
To narrow it down, I’d suggest you create a new survey database and import new FBK file found at C:\Program Files\Autodesk\AutoCAD Civil 3D 2012\Help\Civil Tutorials\Survey-1.fbk. This will tell you if your database is bad.
If you get the same behavior with new drawing, new survey DB and using new FBK file, then I would suggest you to repair or reinstall your Civil 3D (from Control Panel).
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
- Highlight
- Email to a Friend
dwk1204 wrote:I apologize for three issues in one post, but all are driving me nuts.
I think you are mixing up Description Key and Figure Prefix. A Figure Prefix is used to draw the linework and a Description Key assigns properties to the points. A Figure Prefix does not needa * at the end because it is a prefix so the wildcard is assumed. Your Figure Prefix "rr" will match ANYTHING that starts with rr (such as rrisg). Two options that I can see, change the code of one or the other so they don't start with the same prefix or turn off the "Automatic begin on figure prefix match" in your Linework Code Set. If you do this, you'll need to make sure you begin each and every figure you survey.
- Highlight
- Email to a Friend
Are you using a fieldbook file or a point file? If you are using a fieldbook file, make sure you toggle OFF "process linework" in the import settings. The fieldbook already creates the linework. Toggling that on will create linework based on the point descriptions as well as what the fieldbook creates.
- Highlight
- Email to a Friend
Thanks all for the replies..
I tried the field book and new database and all seems to function properly, so not really sure other than as you suggested maybe a bad database.
I understand the difference between the two (as much as I can after a short time of using Civil), but still thought they were linked some how, so thanks for clarifying. So, just out of curiosity, if I am understanding you correctly, what happens after 26 figures are created? Do you go to a Aplha numeric IE: A1?
Again...thanks for responses
- Highlight
- Email to a Friend
You can have multiple figures with the same name, there's no problem with that, you just don't want two figures that represent different things that might conflict with each other.
Example: For my flow line, I code it as FL and therefore I have a Figure Prefix: FL. I also code my fences as FLN and have a FIgure Prefix FLN. Well, you will never have a fence line in your drawing because FLN has the prefix FL. So instead of using FLN for the fence, use something like FX for fence. I always recommend a prefix should have at least 2 letters and often times will need 3 letters. If I just use one letter prefix, then I can only have (as you mentioned) 26 different types of figures.
