• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    rutar
    Rail Track Layout Utility - how add custom Rail type?
    239 Views, 2 Replies
    02-27-2013 12:16 AM
    is it possible to define custom Rail Types in Rail Track Layout Utility for AutoCAD® Civil 3D® 2013?
    There is only combobox with predefined Rail types 49, 54, 60.
    In Help I found: "The rail type defines the standard turnout types (e.g. 49, 54, 60 etc.)or other user defined types "
    , also there is mentioned, that  "...pre-prepared turnout types that are written in the XML file ara_switch.xml"
    I can't find that ara_switch.xml file.
    Any solutions?
    Please use plain text.
    Product Support
    Re: Rail Track Layout Utility - how add custom Rail type?
    03-04-2013 09:23 AM in reply to: rutar
    I installed the utility as well, but I cannot find the ara_switch.xml noted in the HELP menu either. Hopefully someone on the forums has a suggestion while I take some time to look into this further.
    Seth Hall
    Product Support
    GCSO - CSS - FTS
    Autodesk, Inc.
    Being Civil
    Being Civil Twitter
    Being Civil Facebook
    Product Support
    03-08-2013 01:54 PM in reply to: SethHall
    I could not find the ara_switch.xml on my machine or any variation of it. It seems all the files for the utility are located here: C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\Civil
    there is a text file located here called: MSG_TurnOut.txt
    Have you had a look at that?
    Seth Hall
    Product Support
    GCSO - CSS - FTS
    Autodesk, Inc.
    Being Civil
    Being Civil Twitter
