• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    Neilw
    Accepted Solution
    Quantity summary across multiple dwgs
    200 Views, 12 Replies
    11-14-2012 01:37 PM
    I'm looking for suggestions on how to compile quantities for cost estimating when the data is scattered across multiple files. Aside from generating quantities for each drawing in seperate .csv files etc., is there some way to pull the data from all the drawings at once into a single summary file?
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    Please use plain text.
    *Expert Elite*
    Joe-Bouza
    Re: Quantity summary across multiple dwgs
    11-14-2012 01:41 PM in reply to: Neilw
    You talking QTO or simple acad?
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    *Expert Elite*
    Neilw
    11-14-2012 01:57 PM in reply to: Joe-Bouza
    Ideally it would be with one tool but I don't think QTO can extract quantites from XREF's. I know we can use MAP report queries to extract data to .csv files but it won't work on C3D objects. There is the data extraction tool but I expect it has the same limitations.
    I'm wondering if Infrastructure suite has tools for this or can we do it through DWF's?
    WIN 7 64 PRO
    RADEON 6450, 1 GB
    *Expert Elite*
    Joe-Bouza
    11-14-2012 02:58 PM in reply to: Neilw
    correct! only primitive. But I think you may be mistaken about the QTO across files? I haven;t looked at it in a while
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    *Expert Elite*
    Neilw
    11-14-2012 03:22 PM in reply to: Joe-Bouza
    QTO doesn't seem to recognize anything in XREF's Joe.
    WIN 7 64 PRO
    RADEON 6450, 1 GB
    *Expert Elite*
    BrianHailey
    11-14-2012 03:58 PM in reply to: Neilw
    Ah, young padawan, you must try again. QTO does recognize through an xref but you must ensure the pay item file is the same in both files:
    http://screencast.com/t/zUiHt7NjMUw6
    *Expert Elite*
    Neilw
    11-14-2012 05:10 PM in reply to: BrianHailey
    Excellent. Now, how can one determine what pay item files were used on the drawings?
    WIN 7 64 PRO
    RADEON 6450, 1 GB
    *Expert Elite*
    Joe-Bouza
    11-14-2012 06:02 PM in reply to: Neilw
    If I had to guess more than likely there either isn't or its different. And how come I didn't get the check :smileywink:
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    *Expert Elite*
    Neilw
    11-14-2012 06:19 PM in reply to: Joe-Bouza
    I guess you deserve some credit for thinking it was possible so here's a check (Kudo):smileywink:
    WIN 7 64 PRO
    RADEON 6450, 1 GB
    *Expert Elite*
    Neilw
    11-14-2012 09:31 PM in reply to: BrianHailey
    I can't find anything in the help system that states QTO works on XREF's. How did you learn about it Brian?
    Another challenge: can we limit the extraction to the extents of clipped XREF's? I can't make that work.
    WIN 7 64 PRO
    RADEON 6450, 1 GB
