• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Accepted Solution
    Quantity Takeoff Criteria Import
    85 Views, 2 Replies
    11-28-2012 04:07 PM
    Does anybody know how to import Quantity Takeoff Criteria to another drawing??? Created it even in the Settings tab, however when I start another drawing new Quantity Takeoff Criteria is missing.
    Please use plain text.
    *Expert Elite*
    Re: Quantity Takeoff Criteria Import
    11-28-2012 04:53 PM in reply to: Vasily_BC
    You need to create that criteria in your DWT file so that when you start a new dwg, you'll see it. Creating any style in just any old file doesn't mean that it will be there when starting a new file.
    To get the style from one file to another, open them both and drag the style from the settings tab into the dwhg window of the target dwg (not into the settings tab of that file).
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    Active Contributor
    11-29-2012 11:00 AM in reply to: mathewk
    Wow! It works.
    Thank you so much.
