• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Publishing dref'd pipe network in section view sheets
    371 Views, 4 Replies
    07-08-2009 03:27 PM
    I knew this was a problem with 2009. It looks like it still is in 2010, unless I'm doing it wrong.
    I have data referenced a pipe network into my sections drawing. If I have my section plan sheets in layouts of that same drawing, and try to publish from sheet set manager, the pipes won't show up in the output (hard copy, pdf, etc). It doesn't appear to sync upon opening for the publish command.
    I guess I can have my section plan sheets i a separate file (not a problem, I usually do), or promote the pipe network into the sections dwg (not something i prefer).
    Is there some toggle that I haven't flipped, or is this "just the way it is, baby".
    Please use plain text.
    *Himanshu Gohel
    Re: Publishing dref'd pipe network in section view sheets
    07-09-2009 10:19 AM in reply to: petrocat
    > 2010, unless I'm doing it wrong. I have data referenced a pipe
    Could you post some more details on this? You're saying that the pipe
    network is data-referenced into the drawing that has your view
    frames/sheets, and then you create sheets in that same drawing, correct?
    So the pipe network shows in the drawing in model and in the sheet
    layout view, but not when you plot it?
    Are you not seeing the pipe network in a plan view, or are talking about
    the pipe network parts in a profile view?
    Does publishing fail only when you try it from SSM, or does it fail even
    when you plot/publish from Civil 3D?
    This sounds like a bug and I will file a defect on it once we can get
    details and reproduce it.
    Himanshu Gohel. Civil 3D Team, Autodesk, Inc.
    Autodesk Civil 3D Product Information: http://www.autodesk.com/civil3d
    Civil Engineering Community Portal: http://civilcommunity.autodesk.com
    07-09-2009 11:22 AM in reply to: petrocat
    Himanshu,
    I'll try to answer your questions.
    frames/sheets, and then you create sheets in that same drawing, correct? Correct, for example I have a Design.dwg where I built the pipe network, and I make a datashortcut and reference the network into a Sections.dwg where I then make section view, and set up the paperspace with the plan sheets.
    layout view, but not when you plot it? If I plot from that Sections.dwg by plot/publish of the sheets/layouts, it will show up. But, it doesn't plot when the drawing was closed, and I publish those sheets/layouts from Sheet Set Manager. As the Publish is going on, I can see the drawing open up momentarily and it doesnt appear to be syncronizing the data ref of the pipe network. When I look at the finished product (paper, pdf, dwf) the pipe does not show up in the section views. I can then go into the Sections.dwg, where I have referenced the network into, and I will have to manually syncronize the pipe network to make it appear in the sections.
    Uhmm, just the Section View. I haven't tried to print a plan and profile sheet with the network data referenced.
    Publish fail..?? I wouldn't say fail, I would say the datareference isn't sync'd, and it has been just from the SSM Publish from my experience.
    Thanks.
    Active Contributor
    10-06-2009 01:32 PM in reply to: petrocat
    We are having the same problem with Publish. We plot the sheet and the d'refed information is visible in the plots, however if we publish the d'refed pipes are not displayed in the profile. The plan view pipes are static not d'refs. Please help!!! Edited by: sean@hhpr.com on Oct 6, 2009 1:32 PM
    Sean Hulbert
    Member
    Kayte
    Re: Publishing dref'd surface in profile and section view sheets
    10-05-2012 08:58 AM in reply to: petrocat
    Hello, I'm having the same problem with publish in C3d 2011. I've got a data-referenced existing surface that doesn't show up in profiles and sections when the sheet layouts are published to a pdf. I can print each sheet separately - dwg to pdf  - and all looks fine. I hope the source of this problem has been found. Publishing the entire sheet set in one pdf is a great tool. I hate to do each one separatley and then compile...what a pain! I tried the suggestion to toggle 'publish in the background' and it made no difference. Hope someone out there can help. Thanks!
