• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    pserpas
    Publish to PDF Sheetset Mgr - .DWG to .PDF Plots offset
    511 Views, 2 Replies
    09-14-2011 01:02 PM
    When I try to plot a set of files to one PDF, all my plots offset to the right.  This never happens if I Publish to Plotter through Sheetset Mgr. or use the plot dialog in C3D.  Only Publish to PDF through Sheet Set Mgr.  Does anyone know of a setting I should check?
    Windows 7 x 64
    Nvidia GeForce GTS 450
    8 GB Ram
    Intel Core i5-2310 @ 2.90 GHz
    v. F.107.0.0 AutoCAD Civil 3D 2012 SP1
    Please use plain text.
    Product Support
    AlmasSuljevic
    Re: Publish to PDF Sheetset Mgr - .DWG to .PDF Plots offset
    09-16-2011 06:56 AM in reply to: pserpas
    Did you try selecting new window in Plot dialog (what to plot) instead of extents? Then see if program gets better area. Try print preview to see. Also do you get the same bahavior if you use DWG to PDF.pc3?
    Almas Suljevic
    Product Support Specialist
    Autodesk Global Subscription and Support
    Autodesk, Inc.
    Please click on "Accept as Solution" if post helped you resolve the issue.
    *Expert Elite*
    Joe-Bouza
    09-16-2011 08:13 AM in reply to: pserpas
    Sheet set manager want you to use Layout, not extents or window. Also, does the review of you pagesetup show correct?
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
