• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Ron Mills
    Program Failure with metric pipes
    57 Views, 4 Replies
    05-20-2005 05:44 AM
    Can someone try this for me?
    Start a drawing using the "metric by layer" template.
    Change your pipe catalogs to Metric Pipe and Metric Structure
    Create a pipe network by Layout. Under "Network parts list" choose "common
    sanitary sewer" Click "OK"
    using "pipes and structures", draw a simple 2 node, 1 pipe network.
    click on the resulting pipe and bring up the pipe properties
    Under the pipe properties tab, click on inner pipe diameter as if you're
    going to change it.
    It should hang (unless it's just my install), if you click on the rules or
    information tab, then C3D should exit, without error statement.
    I'm only a single seat here. This is fresh install with no modifications
    made to anything.
    C3D 2006, Win XP Pro SP2
    FWIW, I havn't noticed this problem with imperial data.
    Please use plain text.
    *Daniel Philbrick
    Re: Program Failure with metric pipes
    05-20-2005 07:13 AM in reply to: *Ron Mills
    yes - it is reproducible.
    thanks for the detailed steps.
    Daniel Philbrick
    Autodesk, Inc.
    "Ron Mills" wrote in message
    news:4851563@discussion.autodesk.com...
    going to change it.
    made to anything.
    *Ron Mills
    05-20-2005 07:23 AM in reply to: *Ron Mills
    "Daniel Philbrick" wrote in message
    news:4851775@discussion.autodesk.com...
    Whew!
    *Matt Kolberg
    05-20-2005 09:20 AM in reply to: *Ron Mills
    Whew, as in, "It's not just me"? Ot whew, as in, "Man, another bug!"?
    Sorry, Daniel. I love the product, but there is an issue or two. :smileyhappy:
    Matt Kolberg
    news:4851755@discussion.autodesk.com...
    Whew!
    *Ron Mills
    05-20-2005 10:03 AM in reply to: *Ron Mills
    "Matt Kolberg" wrote in message
    news:4852008@discussion.autodesk.com...
    I think the Whew covers both instances...
