• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    rkmin
    Accepted Solution
    Problems with Creating Points with Certain Descriptions
    96 Views, 2 Replies
    11-29-2012 02:57 PM
    I created a Description Key called "EP" and it will land in a "S-PTS-EP" layer automatically.
    I then created a Description Key called "NEW EP* " and created it to land in a new layer called "S-PTS-EP-NEW". But, when I manually create a point called "NEW EP" or "NEW EP BC", it does not land in the "S-PTS-EP-NEW" layer.
    Is there some switch I need to turn on or is my description not complying with some naming convention?
    Please use plain text.
    *Expert Elite*
    Re: Problems with Creating Points with Certain Descriptions
    11-29-2012 04:15 PM in reply to: rkmin
    You can't have spaces. Make it NEW-EP.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    Valued Contributor
    rkmin
    11-30-2012 10:50 AM in reply to: mathewk
     Thank you.
