AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Problemas con Autocad 2013
- Highlight
- Email to a Friend
Hola buen dia, he adquirido el auto cad Civil 2013, y anterior mente tenia el civil 2012, he tenido problemas para ver archivos de autocad civil 2013 en otro equipo que tiene instalado autocad civil 2012, algien me podria ayudar con este tema. Gracias
Re: Problemas con Autocad 2013
- Highlight
- Email to a Friend
I used Google to translate:
"Hello good day, I purchased the AutoCAD Civil 2013, and earlier had the civil mind 2012, I had trouble seeing autocad 2013 files on another computer that has civil autocad 2012, algien could help me with this issue. Thanks"
Are you trying to make a file in 2013 and view it in 2012? With Civil 3D this will not work. You can "Save As" but you will only see the regular lines and text...you will not see the Civil 3D objects.
If you use the command ExportToAutoCad this will explode all objects so that they can be viewed in an older version. But they are no longer Civil 3D objects in this case.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
