• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    bingeomatics
    Accepted Solution
    Problem in changing coordinate systems while importing points
    182 Views, 2 Replies
    11-03-2012 03:30 AM
    Hello, colleagues. I want to know why I can't change coordinate of points while importing points from Points menu?
    I created new file, assigned any coordinate syste to the model. Opened Import points windows there, created new file format which there I assigned Coordinate zone transform to the coordinate system of the text file and imported my text file. But the coordinates of points didn't chanched or transformated. When I do it by Survey in Toolspace its works good. I want to know whether I did any wrong or it is problem of software.
    I use AutoCADCivil 2013 64 bit in Windows 7 64 bit!
    Binnat Khalilov
    Please use plain text.
    *Expert Elite*
    Re: Problem in changing coordinate systems while importing points
    11-03-2012 03:46 AM in reply to: bingeomatics
    I think the fields "Easting" and "Northing" are not transformed, my problem is that I don't know the word for the fields you have to chose instead in English. My personal translation would be: use "Raster-Easting" and "Raster-Northing" instead of "Easting" and "Northing".
    Hope you find the corresponding fields in your dialog and the transformation will then work!
    HTH, - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    bingeomatics
    11-03-2012 04:12 AM in reply to: alfred.neswadba
    Thanks, Alfred NESWADBA!I changed filelds names from "Northing" and "Easting" to "Grid Northing" and " Grid Easting" and it works good.
    :smileyvery-happy:
    Binnat Khalilov
