AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Problem in Alignment of civil 3d 2010
- Highlight
- Email to a Friend
hello everyone
I have a problem in alignment of civil 3d 2010 i show you my problem by an example
l create a line and then i use create alignment of obect to refer line to alignment at first i change interval of every station to 30m it works well (fig 1)
but i want my alignment to start from 98+00 so i select my aligment and i open alignment properties and in station control i change station 0+00 to 98+00(fig2) so my alignment should change 98+00,98+30,98+60,.....but i see that my alignment starts 98+00,98+10,98+40,98+70,...(fig3)
I don't know why i see this problem and i haved asked so many people but they don't know the reason
Re: Problem in Alignment of civil 3d 2010
- Highlight
- Email to a Friend
That must be a feature of the software. It does not want to display stations that are not evenly divisible by the increment.
If it's important to have those labels increment exactly as you want, you could leave the alignment stationing starting at 0+00, create an expression that adds 98000 to the alignment station, and then use the expression in your major station labels. The actual stationing will start at 0+00, the labeling will start at 98+000, and the increment will count up from 98+000 to 98+030, 98+060, etc.
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
- Highlight
- Email to a Friend
that is wierd!
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
- Highlight
- Email to a Friend
How invested are you in starting at 98+000? You could change the start station to 90+000, since it is evenly divisible by 30. 98+000, or 98,000 is not. 99+000 also works.
If you need to start at 98+000 and label every 030 from there, an expression label may be your best option.
HP Z600 8 Gig RAM
Civil 3D 2011
- Highlight
- Email to a Friend
Changing the station delimiter position to match the number of zeros you want after the plus might do the trick.
See attached.
- Highlight
- Email to a Friend
thank you for your reply
I tested but i did'nt get correct result
The only way to solve my problem is experssion(fig1)
- Highlight
- Email to a Friend
You metric guys have me somewhat confused. I thought you always have the plus (+) sign followed by 3 digits. So I am thinking you must be using an imperial template. Just a thought.
Bill
- Highlight
- Email to a Friend
Nope. I used a metric template and made it work using an expression. Anyway, it sounds like he's up and running. In my example, the plus was left of the third character, but it doesn't matter. It's a divisibility thing.
Redding, CA
