• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Boundariesllc
    Problem Reimporting FBK
    121 Views, 6 Replies
    01-09-2013 06:44 AM
    Lets start out by saying this did not happen in any other version of Civil 3d. We recently did a computer upgrade to our office. So when it came time to reload civil 3d, we chose to go with 2012 version. All was fine until I had to reimport an fbk.
    I will typically start out by stripping the control loop out of the fbk file and balancing and making a text file of the loop (backup). Then I will bring in the rest of the location on to the balanced loop. If for some reason I need to reimport those locations for some reason it will remove any control points occupied in the last fbk file. Please let me know if something has changed or if the fbk file looks in correct.
    Any help is appreciated
    Windows 7 x 64 Professional
    Nvidia Quadro 4000
    24 GB DDR3
    Dual core Xeon W3505 @ 2.53 GHz
    Civil 3D 2012 SP 2.1
    Civil 3D 2013 SP 1
    Please use plain text.
    *Expert Elite*
    TRogers
    Re: Problem Reimporting FBK
    01-09-2013 08:18 AM in reply to: Boundariesllc
    Are you creating Networks?
    If the issue was resolved by this method, please click on "Accept As Solution"
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    Member
    Boundariesllc
    01-09-2013 08:22 AM in reply to: TRogers
    yes I am creating network,
    Nvidia Quadro 4000
    24 GB DDR3
    Civil 3D 2013 SP 1
    *Expert Elite*
    TRogers
    01-09-2013 08:24 AM in reply to: Boundariesllc
    I am assuming you have all Updates and Hotfixes installed?
    http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240698#section2
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    Member
    Boundariesllc
    01-09-2013 08:32 AM in reply to: TRogers
    Yes We are currently up todate.
    Nvidia Quadro 4000
    24 GB DDR3
    Civil 3D 2013 SP 1
    02-12-2013 08:45 AM in reply to: Boundariesllc
    Any news on this?
    -John J. Rauch, P.E.
    Member
    Boundariesllc
    03-27-2013 08:45 AM in reply to: Boundariesllc
    No Still having the same problem. I have a work around, strip all control in to one fbk file and and all sideshots into another fbk file. I need to import the control file into one Survey Network (control) and then import any other fbk file into a different network (sideshots). Seems to be the only way to fix this.
    Not a good remedy on large scale jobs that continue to grow.
    Seems like a little to involved and should be easier.
    Nvidia Quadro 4000
    24 GB DDR3
    Civil 3D 2013 SP 1
