• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    wedzisi
    Accepted Solution
    Printing problems with window mode in Civil 3D 2013
    543 Views, 9 Replies
    10-11-2012 10:32 PM
    hi i have problem in civil 3D 2013 when i try to print with window mode , when i am try zoom in with mouse scrol printig function is disapiaring and after i must klick escape  several times for re use print eny one can tell me what is problem meby bug or  something
    thx.
    p.s. sory for my bad english
    Please use plain text.
    *Expert Elite*
    Re: Printing problems with window mode in Civil 3D 2013
    10-11-2012 11:52 PM in reply to: wedzisi
    I can confirm that, but as I normally print using layouts and so not using "Window" to define the plot-area it's not something really hurting (for me).
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    *Expert Elite*
    rkmcswain
    10-12-2012 07:46 AM in reply to: wedzisi
    Agreed. Known bug.
    *Expert Elite*
    AllenJessup
    10-12-2012 08:18 AM in reply to: wedzisi
    So a workaround would be to draw lines from or center circles at the point you need to pick for your window. Make them big enough so you can select them without zooming in and put them on a no-plot layer.
    Or just plot from a layout.:smileyhappy:
    Allen
    Active Member
    wedzisi
    10-13-2012 03:02 AM in reply to: AllenJessup
    yeah you are right also i am ploting from lay out but somtimes i am geting lage drowings for ex. 13km road plan its tender document and the i need just som section i am ploting with window  thes is not so big problem but  somtimes i am forgeting and geting nervos :smileyvery-happy: so if autodesk will fix it will be beter
    New Member
    11-05-2012 04:30 PM in reply to: wedzisi
    It says at the top of the forum this has been solved. Is there a hotfix for this one yet?
    Yes I can get around it but still annoying..like docking a command line to get around glitches.
    *Expert Elite*
    rkmcswain
    11-14-2012 08:13 AM in reply to: wedzisi
    New Member
    04-11-2013 09:01 AM in reply to: wedzisi
    After hours of research I have yet to find a solution which fixes this problem. From what I have been told this issue has been resolved in Civil 3D 2014. Can someone from Autodesk please chime in on this subject regarding a upcoming HotFix or soltion to fix this problem.
    Mike
    *Expert Elite*
    04-11-2013 09:08 AM in reply to: mikeg
    I'm not from Autodesk, but if I'm allowed to try it: I can't reproduce this issue with C3D2014 (German, Win7x64)
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    04-11-2013 09:24 AM in reply to: alfred.neswadba
    One work around that works "sometimes" to get out of the loop is to right click and hit enter and it will give you back your pick appature.  It's not 100% but I have found it better than hitting escape 1000 times before starting the plot process over again LOL
