• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Pressure Pipe Networks: setting Min cover AFTER laying out horizontal design
    137 Views, 1 Replies
    01-02-2013 01:15 PM
    Good afternoon.
    I created a pressure pipe network but during horizontal design I did not specifiy a minimum cover depth.
    After completing the horiz design I created a profile.  The network parts all have a centerline elevation of 0.00, which is expected.
    Now I want to go back and specify the minimum cover but I don't know how.  If I type in 3-ft as part of the Network Properties menu, nothing happens.  And if I click on the "follow surface" button then the pipes and fittings are set at minimum depth but it adds vertices to the pipe parts which I don't want.  I would like only the pipe ends to be used to set the depth.
    Any suggestions on how the min cover can be set other than to redraw the network with the depth setting set from the beginning?
    Please use plain text.
    *Pro
    Re: Pressure Pipe Networks: setting Min cover AFTER laying out horizontal desig
    01-03-2013 01:57 PM in reply to: HC1975
    assign the rules to the pipes and then select the pipes i think one at a time and right click apply rules.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
