• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Pressing minus key causes window control tool to open.
    502 Views, 3 Replies
    05-02-2011 11:18 AM
    Occasionally something happens such that when I press the minus key the 'window tool' opens.  It's been so long that I can't recall what it's called, but it is the Windows tool for maximizing/minimizing/restoring a child window.  The keystroke to call it up is alt-minus (similar to the alt-spacebar command for invoking the tool for a parent window).
    It will happen when I'm drawing a line by station & offset and try to enter a negative offset; Windows sees the minus sign and takes over, opening up the child window control thingy.  Another way is if I try to start the Layer command on the command line by preceding it with a minus sign; -LA.
    C3D 2011 ver. 2, Win 7 Enterprise.
    Win 7E 64-bit, Intel i7, 12 GB
    C3D 2012
    Please use plain text.
    Re: Pressing minus key causes window control tool to open.
    05-02-2011 02:31 PM in reply to: jeff_rivers
    Yep, that's been bugging me also. :smileymad:
    Especially in the instance when you are a poly line that runs through consecutivly numbered points.
    Ideas anyone?
    Nathan
    05-17-2011 12:36 PM in reply to: jeff_rivers
    I discovered a fix that seems to be permanent at least during the C3D session.
    When pressing the minus key opens up the Windows Keyboard Shortcut to resize the window:
      1. Click with the cursor in the C3D command line.
      2.  Before pressing any other key, press 'esc' one time.
      3.  Control should now return to the C3D command line, and further presses of the minus key shouldn't bring up the Window Resize shortcut command.
    C3D 2012
    Active Member
    08-25-2011 10:24 AM in reply to: jeff_rivers
    I have this problem as well when drawing feature lines, which often have negative grades.  It's very irritating, hope they've fixed in in 2012.
    C3d 2011, V3.  Win 7 Prof, 6 GB, 64 bit.
