• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    Re: Possible to create a surface that uses the highest elevation of two surfaces
    09-28-2011 03:07 PM in reply to: AllenJessup
    Glad to see so many people thinking about my question.  The reason I asked was because I was hoping for an easy way to determine the tidal prism for a marsh.  In this case the tidal prism is the volume between the MLLW and the MHHW.
    I have the surface for the marsh topography.  I was going to create two more surfaces as planes, one for the MLLW elevation and the other for the MHHW elevation.
    I wanted to "clip" the marsh topo with each of these surfaces to create two new surfaces.  One representing the site at low tide, the other at high tide.  From there I would do a comparison surface to get the volume difference.
    I just couldn't figure out how to do the "clip" surfaces easily.  Yesterday I wasn't thinking of it in terms of clipping, but now that I am perhaps someone will come up with a really easy way to do what I am asking.
    In the end I ended up creating two volume surfaces, one for the volume between the MLLW and the topo and another for the MHHW and the topo.  I then took the difference of the two fill values to get the tidal prism.
    Erik
    Please use plain text.
    Distinguished Mentor
    09-28-2011 08:11 PM in reply to: erik
    From each of your plane surfaces, turn the border display on, then extract the border from the surface. You can then use this to clip a copy of the marsh surface to create your two surfaces for volume calculation.
    If this fixed your issue, click on "Accept as Solution"
    Andrew Puller
    Maitland, NSW, Australia
    Windows 7 Enterprise 64bit
    Intel core i7 2600 @ 3.40 GHz with 16GB Ram
    Civil 3d 2013 64bit
    09-29-2011 06:04 AM in reply to: erik
    Easier solution then.
    a) use bounded volumes
    b) make a flat boxed feature line bigger than (or = to) your area of interest with elevation=LW, then HW, creating a flat surface by adding the feature line as a beakline to an empty surface.
    Compute a volume between your marsh surface and your LW, and then again your HW. Ignore the cut volumes, using only the fill (vol between lower marsh surface and higher LW/HW surface). The cut volume is where the marsh is above your water levels and should be insignificant. Break out a calculator and take the difference.
    Eric Collins, P.Tech.(Eng.)
    Win 7 Pro SP1 64 bit
    Intel i7 3770 @ 3.40 GHz
    16 GB RAM
    Civil 3D 2014 (IDSP)
