AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Possible to create a 3D Object that gives you volume?
- Highlight
- Email to a Friend
I created an enclosed "object" adding break lines to two different surfaces. (Please refer to the attached drawing)
The blue surface shown on the attached drawing is a set of break lines added to "Surface A" and then the red is the other set of break lines added to "Surface B". I have already generated the volume enclosed within the surfaces by doing a surface to surface volume calculation.
My Question:
I want to combine the enclosed volume created by Surface A & Surface B into a 3D "Block" that give me the volume information. Is there a way?
Thank you
Re: Possible to create a 3D Object that gives you volume?
- Highlight
- Email to a Friend
Really confused by what you mean as a "3D Block that will give volume information"...
Are you now trying to create a 3D solid of the difference...? If so, what is your end purpose? How do you intend to use this?
- Highlight
- Email to a Friend
Sinc wrote:what is your end purpose? How do you intend to use this?
I guess he wants to calculate the earthwork, i.e. how much terrain to take away from blue surface to obtain the red one.
- Highlight
- Email to a Friend
50Gb Crucial Adrenaline SSD Cache
Win 7 Pro x64
Intel Xeon 2.4GHz
8Gb Ram
ATI Firepro 4800 Dual Monitor
Dell T5500
- Highlight
- Email to a Friend
If a volume is the key end goal, then yes, a volume surface is the way to go. You can also use the "Volumes" tool (on the Anayze tab in the Ribbon), but that is not persistent, and you have to redo everything once you close out of that tool. So creating a Volume Surface is typically more-useful, unless you are "just browsing".
Was just confused by the fact that the OP indicated he had already created a volume surface, and now wanted a "3D Block"... not sure what that is, or how it would be used. Or maybe the OP used the "Volumes" tool, instead of creating a Volume Surface...? That's why I was asking for clarification.
- Highlight
- Email to a Friend
Sinc,
I think this is akin to creating a interference object in base/vanilla autocad as a 3D solid. What the OP might be able to do is to take the 2 surfaces, extract out the contours. Then use the 3D "Loft" command to create a surface object. Cut a 3D cube with the plane(s) to create a 3D Solid & then compare/interference check between the two solids to get back to C3D's volume surface in 3 dimensions versus a 2.5D comparison between 2 surfaces (cut/fill at elevation).
But I'm not sure why this would have any advantage over C3D unless you're looking at something like a mining ore body, where there is other (more expensive) software that has features we dont....
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
- Highlight
- Email to a Friend
Ah yes, forgot about that, since I don't do mining surveys. (This is an area where Carlson is way ahead of Autodesk, although I still think Autodesk is ahead for most users And Calrson Mining is actually CHEAPER than C3D, BTW...)
- Highlight
- Email to a Friend
True - Carlson escaped me - I was thinking of Vulcan, which I heard rumors of $100k/seat....
C3D 2011
- Highlight
- Email to a Friend
thepworth wrote:Cut a 3D cube with the plane(s) to create a 3D Solid
Are you really sure you can trim a solid cube with a "loft" surface, sir..?
- Highlight
- Email to a Friend
I had a roundabout way to do it, I think it may have been a "skillbuilder" exercise that I used as a teaching exercise for my 3D Autocad class I taught. If I can find my source or a .pdf, I"ll gladly post.
C3D 2011
