• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Pond contour areas / volumes
    1022 Views, 4 Replies
    08-24-2011 05:37 AM
    I remember in LDT there was way to create a pond database or something by selecting polylines. From there you could get a volume report, and areas of each contour.  Is there anything similar to that in Civil 3D?  I have about 40 new pond areas and would like to get some quick areas of each contour per lake and be able to view/print some kind of organized report.
    Thanks!
    Civil 3D 2009
    Civil 3d 2012
    Please use plain text.
    Product Support
    Re: Pond contour areas / volumes
    08-24-2011 06:25 AM in reply to: wvyhonsky
    Stage Storage possibly?
    Seth Hall
    Product Support
    GCSO - CSS - FTS
    Being Civil
    Being Civil Twitter
    Being Civil Facebook
    Active Contributor
    08-24-2011 01:44 PM in reply to: SethHall
    Great...that is what I was looking for.  Now if could only append each basin report into one file.
    08-24-2011 01:54 PM in reply to: wvyhonsky
    Once you have the stage/storage data, press the 'Create Report' button on the bottom of the dialog box and it will generate a tab-deliminated text file for you. Do this for each pond, then you can merge that data into a single text file, word document, or Excel spreadsheet. I do it all the time.
    Windows 7 64-bit
    HP Z600 8 Gig RAM
    Civil 3D 2011
    Active Contributor
    08-24-2011 02:05 PM in reply to: ccoles
    Thanks.  Sounds like a good plan!
