• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    Polylines with FeatId
    93 Views, 2 Replies
    10-01-2012 09:48 AM
    Is there anyway to read the featId attribute of a polyline and assign the elevation to the polyline? All the polylines are at elevation 0. Is there a lisp routine to do this?
    PS: I do not have the shp file from GIS only the AutoCAD drawing with the polylines already created and their featId.
    Thank you in advance for any input.
    Please use plain text.
    *Expert Elite*
    Re: Polylines with FeatId
    10-01-2012 10:31 AM in reply to: Spike55
    A few years ago I wrote a routine for a customer who wanted to do exactly what you describe. If you send the drawing, I can modify it work work for you.
    Tim
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    *Expert Elite*
    AllenJessup
    10-01-2012 11:03 AM in reply to: Spike55
    You may still be able to use a Mapquery to query the polylines from that file and add the featid field as the elevation. Find instructions [HERE] in post #3. Ignore the expression for converting the elevation and only use the elevation stored in freatid.
    Allen
