• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    neilyj
    Polylines as width targets
    241 Views, 6 Replies
    02-07-2012 02:03 AM
    Per attached screenshot - can the polyline Name field be edited anywhere to give a meaningful name??
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Please use plain text.
    Distinguished Mentor
    Re: Polylines as width targets
    02-07-2012 07:12 AM in reply to: neilyj
    I have never found a way to change it. I wish we could though.
    Jeff Paulsen
    Civil 3D 2012 SP3 | Win 7 64-bit SP1
    Xeon E5-1620 @ 3.60GHz, 16GB Ram | NVidia Quadro 600
    02-07-2012 07:56 AM in reply to: neilyj
    I've gotten into a habit of converting the polylines to alignments just so I can get a name to show up for targets. Makes it alot easier to have names.
    Civil 3D 2013 x64
    Civil 3D 2014 x64
    Windows 7 64-bit
    6GB RAM
    neilyj
    02-07-2012 07:59 AM in reply to: neilyj
    Thanks for the replies - the alignments trick is a useful workaround but could clutter up the drawing quite quickly...:smileyfrustrated:
    neilyj
    Valued Contributor
    02-07-2012 12:14 PM in reply to: neilyj
    neilyj,
    I like to use Feature Lines specifically for this.  Create a Site specifically for your Horiz Targets, and also make sure they are on a layer all by themselves.  Also when creating the FL make sure you always NAME it!!!  This way it will show up in the Targets Dialog box with a name.  I find it no different that using a Polyline.   No need to use a FL style for this.
    02-07-2012 12:21 PM in reply to: C3D_User
    That's a great tip.:smileyhappy:
    I never thought about using a feature line because I did not need the vertical component to do a widening. I will use named feature lines in the future.
    Jeff Paulsen
    neilyj
    02-07-2012 01:28 PM in reply to: neilyj
    Agreed - that's the tip of the year ...so far
    neilyj
