• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Re: Polygonal Viewport question
    12-18-2012 10:57 AM in reply to: mnyrac
    I recently got a new computer, with a brand new license of Civil 3d 2012.  I am still having issues with viewports.  When I create a polygonal viewport, it separates the polyline and the viewport if I click on them individually.  It must be a setting somewhere?
    Caryn
    Please use plain text.
    Valued Contributor
    C3D_TomR
    12-20-2012 04:04 PM in reply to: mnyrac
    I am unable to replicate the issue in C3D 2012 or C3D 2013. Every time I create a polygonal viewport and select it I get both a polyline and a viewport in Properties Palette though the vewport is the default object visible in the Properties Palette unless I use Selection Cycling to choose polyline.
    *Expert Elite*
    rkmcswain
    12-31-2012 07:17 AM in reply to: C3D_TomR
    ^^^^^^^^^^^^ I agree with the above.
    Also -- I didn't test it, but if either the polyline or viewport is on layer "Defpoints" and layer 0 is frozen - there is no telling what sort of side effects may occur.
    Active Contributor
    12-31-2012 09:01 AM in reply to: rkmcswain
    I have attached a test drawing with a polygonal viewport in it.  What I have found is that as long as I have cycle selection on, I can choose the viewport.  But the viewport and the polygon border remain separate.
    If you all say that's the way it is, no problem.  I can work with it.  But it just seems odd to me that they would be separate.
    Caryn
