• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Accepted Solution
    Points will not display in drawing
    208 Views, 2 Replies
    10-09-2012 05:11 PM
    I have a drawing where points that I create will not display.
    • I have created points in this drawing before.
    • Previously created points display fine.
    • Points created in another drawing and imported into this drawing display fine.
    • All layers have been turned on and thawed, to make sure it's not a layer issue.
    • "All points" point group is the top point group.
    • When I create a point manually everything seems to work fine, info is echoed to the command line, etc., but then nothing happens.
    Obviously it's a setting somewhere, but it is driving me up the wall trying to figure out what setting.  I'm sure I will slap my forehead when told what it is.  Thanks.
    Windows 7-64
    8GB RAM
    AutoCAD Civil 3D 2013
    Please use plain text.
    Valued Mentor
    Re: Points will not display in drawing
    10-09-2012 07:39 PM in reply to: deltacoolguy
    Check the point #, could be trying to overwrite, it's a bug
    10-09-2012 08:54 PM in reply to: rl_jackson
    That was it.  Thank you very much.
    Windows 7-64
    8GB RAM
