• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Accepted Solution
    Points Remain after Removing Feature Line from Surface
    188 Views, 9 Replies
    12-11-2012 02:32 PM
    I needed to remove a feature line that I used as a breakline when creating a surface.   When I removed the feature line from the definition of the surface, the grading did not change.  It appears the points created by the feature line remain which is why grading didn't change.  The only work around was to delete these points.   I noticed the same thing happens when I removed the surface boundary and inserted a new boundary.  Any help understanding why these points remain and how to remove when I delete boundary and feature line from surface?
    Thanks in advance.
    Please use plain text.
    *Expert Elite*
    Re: Points Remain after Removing Feature Line from Surface
    12-11-2012 02:39 PM in reply to: JOHNMCMENAMIN3259
    My only thought is: are you rebuilding the surface after you remove the breakline or boundary?
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Active Member
    12-11-2012 02:42 PM in reply to: JOHNMCMENAMIN3259
    Yes - I rebuild the surface after the removal.
    *Expert Elite*
    BrianHailey
    12-11-2012 03:03 PM in reply to: JOHNMCMENAMIN3259
    My guess, go to the surface properties of your surface and on the Definitions tab turn off "Copy deleted dependent objects"
    HERE
    Active Member
    12-12-2012 10:21 AM in reply to: JOHNMCMENAMIN3259
    I already had checked that since that would make the most sense.  But already was set to “NO”.  Not sure if this related but when I tried to “simplify” the grading in a particular area and then “removed” the simplify from the definition, those points also remained and did not delete.
    *Expert Elite*
    12-12-2012 10:30 AM in reply to: JOHNMCMENAMIN3259
    You've probably done this since this has been ongoing, but have you shut down C3D, restarted C3D and reopened the drawing? I've had cases where no surface updates would occur until I did this.
    Jeff_M, also a frequent Swamper
    Distinguished Contributor
    12-12-2012 10:41 AM in reply to: JOHNMCMENAMIN3259
    When you built the surface, did you do any old-school Land Desktop edits like flipping triangles, or adding and deleting TIN lines?  I had a project once where mystery edits kept pulling the surface up and down by where feature lines used to be.  I was tearing my hair out, and eventually looked in the edits box and saw there were hundreds of triangle flips and edits that somebody else had done:  Once I deleted all those the surface fixed itself.
    My general advice is don't ever use those old-school edits--find alternate ways to add data by modifying and adding more feature lines.
    Hopefully this helps,
    Jeremy
    Active Member
    12-12-2012 10:48 AM in reply to: Jeff_M
    Yes - did try rebooting and no change to surface.
    Active Member
    12-12-2012 11:19 AM in reply to: JOHNMCMENAMIN3259
    I believe I resolved problem - I went through what I had included in my surface building under "Definition" tab.  I saw I had "Create Snapshot" in the definition which I believed copied all of my surface points.  My drawing recently crashed and it may have been created at that time.  When I removed "Create Snapshot" from the definition, all of the old unwanted points went away.    Thanks all for responding.  While the responses didn't directly resolve my problem, it forced me to look in areas that I may not have otherwise.  Thanks for taking the time to respond.
    *Expert Elite*
    BrianHailey
    12-12-2012 05:35 PM in reply to: JOHNMCMENAMIN3259
    You should mark your post as an answer. That way when others are searching they will see this post has an answer to the question.
