• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Tyler Townes
    Points Display Properties
    104 Views, 1 Replies
    12-22-2004 11:59 PM
    Is it possible to change a select group of points' so called "display properties" (text size; lingo from LDT) without creating a new/unique point style? Thanks, Tyler Townes
    Please use plain text.
    Re: Points Display Properties
    12-28-2004 07:42 AM in reply to: *Tyler Townes
    No, it is not possible. Points are displayed based on Point and Point Label Styles. Therefore, if you want a SELECT group of points to have unique display properties, then you need to create a unique point label style. Otherwise, if you edit the point label style already being used, you will change all points using this style.
    The point label style will control the text style used, as well as the layout and dragged state components and displays (text formatting, layers, borders, arrows...).
    The point style will control the marker format and the display of markers and labels (visibility, layer, color...)
    Hope this helps...
    Charlie Ogden, PE - Application Engineer
    cogden@microdesk.com
    Microdesk, Inc.
    (800) 336-DESK (3375)
    http://www.microdesk.com
    Microdesk is the leading provider of Architectural, Civil/Survey and GIS/FM
    solutions based around Autodesk and ESRI technologies.
