• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    AllenJessup
    Point shift on convert Land desktop points
    142 Views, 2 Replies
    11-26-2012 12:44 PM
    I had inserted a Land Desktop drawing containing points in to a C3D 2012 drawing. There was a small difference in coordinates. I used Autocad move and rotate to adjust. This was fine because I only needed a visual reference. Now someone wants the information and I need to convert the Aecc points to Civil cogo points.
    The problem is that the convertldtpoints command doesn't use the location of the point marker as the coordinates for the converted points. It uses the Northing-Easting stored in the AECC_Point object. Those are the pre-adjustment coordinates.
    Does anyone know a way of getting around this?
    Allen
    Civil 3D 2012 SP 2.1
    Dell Precision T7400
    Xeon CPU 3.16 GHz
    Nvidia Quadro FX 4600
    12 GB RAM
    Win 7 Pro, 64-bit
    Please use plain text.
    Re: Point shift on convert Land desktop points
    11-26-2012 01:29 PM in reply to: AllenJessup
    I remember hitting this on one of my very first C3D projects.  My solution: note to self "Convert First, then Move"
    Not sure if this is going to help you now though.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    AllenJessup
    11-26-2012 01:35 PM in reply to: troma
    That's near to what I ended up doing. I marked 2 solid points. Then I did the conversion and let the points revert to their original coordinates. Then I did a move and rotate based on the positions I had marked.
    The only other challenge was selecting only those points I'd just converted and not points already existing in the drawing. I locked the layers that contained the points I didn't want to move and then used QSelect to select all the Cogo points.
    Allen
