• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Breslin, Kevin
    Point selection problems
    118 Views, 3 Replies
    10-05-2003 10:04 AM
    For viewing functions and in some cases selecting points to create a group
    for example you will see strange behavior.
    For example, if you import points from a file, select one point by an
    implied window then use 3DORBIT or Object Viewer you will get all of the
    points not just the one you selected. Also, when selecting points for a
    point group by selecting points in the drawing, you will get nothing if you
    make an implied window, however if you make an implied crossing window the
    program will accept the points.
    Kevin Breslin
    Please use plain text.
    *Slater, Daniel
    Re: Point selection problems
    10-22-2003 01:52 AM in reply to: *Breslin, Kevin
    Kevin,
    Points in Civil3D are not objects, they are simply data - this saves
    us over 90 bytes per point - the point group is the object. This is
    what's causing the behavior you're seeing in 3DORBIT and Object Viewer.
    The window selection issue is a known defect we're looking into.
    Dan Slater
    > Kevin Breslin
    *Antoljak, Strahimir
    Re:
    11-02-2003 10:20 PM in reply to: *Breslin, Kevin
    that's an interesting statement, because when you list
    the point, under "Select objects:" you get both in the list:
    AECC_POINT_GROUP and
    AECC_COGO_POINT
    thanks,
    Strah @ Langan
    "Daniel Slater" wrote in message
    news:smileyvery-happy:3DE285CE68296A853A43FFA1CE59AB2@in.WebX.maYIadrTaRb...
    > Kevin,
    > Dan Slater
    group
    you
    the
    > > Kevin Breslin
    *Putnam, Chris
    Re:
    11-03-2003 12:18 AM in reply to: *Breslin, Kevin
    I suppose the "AECC_COGO_POINT" tag is a bit misleading in this case. The
    point group actually prints all of this information in response to the list
    command. Perhaps it would be clearer if we hadn't used a DXF style name to
    label the individual points. If you look very carefully, you'll see that
    the AECC_COGO_POINT tag is indented slightly more than AECC_POINT_GROUP (by
    1 character). Also notice that the AECC_POINT_GROUP contains an entry for
    "number of points selected". Both are indications that the point is really
    not a separate object.
    Chris Putnam
    Software Engineer
    AutoCAD Civil 3D Team
