AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Point label dragged state settings
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm trying to set up my point label styles and I don't understand how the dragged state settings work. The default setting is "as displayed" but then the leader does not flip, if I change the settings to "stacked text" the leader flips but the text is out of order. See the attached plot of some points to see what I mean, default on the right and stacked text on the left.
How can I set the point label so the leader will flip and keep the label components in the default order?
Re: Point label dragged state settings
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Be sure to check the justification in the label editor. Setting the justification will cause your text to stay lined up propperly when you move the callout.
Civil 3D x64 2012
Win 7 x64 Ultimate
I7 3820 (3.6ghz quad core with HT)
32gig RAM (Corsair XMS3 4x8g)
Intel x z79 mobo (BOXDX79TO 2011 socket)
Radeon HD 7850 2gb GDDR5
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Justification seems fine, its that the point number should be first, then the point description under that. Thats how it displays by default, but by default the leader does not flip.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In the Stacked Text mode the text components are placed in the same order in which they are added to the style. You will need to edit the style to accomplish this.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Right I see that the point description is component 1 and that the point number is component 2, is there a way swap the two?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
No, can't swap them. But you can copy the elevation & description components, change the anchors to reference the copies, delete the originals, then rename the copies.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks to all for the advice, I got it figured out.
Using the copy and delete method suggested above I got them in the order that I wanted.
Then I had to adjust the Anchor component, the anchor point and the text attachment point of all three componants, kinda tricky.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Glad you got it worked out. For future reference, when posting replies in the forum, please be sure to hit the Reply button on the message to which you are replying to. Your last message looks like you you were replying to yourself.
If you find a response which answers your question, please be sure to accept the actual post which helped you as the solution. This will help future searchers quickly find answers to their own questions. Thanks!
