• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    dcanete
    Point elevation takes on elevation of snapped object
    176 Views, 7 Replies
    12-19-2012 10:07 AM
    Hi All,
    When I snap a point to an object, the point takes on the elevation of the object. I would rather the point's elevation stay as is.
    I realize this topic has been discussed on other forums but I have tried all the suggested solutions with no success:
    -changing osnapz variable
    -latest civil 3d service pack
    A few weeks ago I did not have this problem but once my computer was switched to the company's global server and c3d was reinstalled the problem appeared. Furthermore (post switchover), when a colleage of mine prepared a simple test drawing with just a line and a point, he was able to snap to that line without the point changing elevation. When he sent that drawing to me and I tried snapping the point to the object, the same problem occured with the point taking the elevation of the line object. I suspect it is a system variable issue - any comment or suggestion would be greatly appreciated.
    Derrick Canete
    Please use plain text.
    *Expert Elite*
    Re: Point elevation takes on elevation of snapped object
    12-19-2012 10:45 AM in reply to: dcanete
    The version and Service Pack you are using is?
    Jeff_M, also a frequent Swamper
    dcanete
    12-19-2012 10:50 AM in reply to: Jeff_M
    Civil 3d 2012 service pack 2.
    Service pack 2.1 is on the autodesk website - I downloaded and tried to install but it said that my CAD was already up-to-date.
    *Expert Elite*
    12-19-2012 11:05 AM in reply to: dcanete
    What you are seeing the designed behavior for moving points. It was actually broke in pre-SP2 C3D2012. See the beginning of THIS thread for a lively discussion. Also see the readme doc for the SP2 (or Sp2.1).
    dcanete
    12-19-2012 11:38 AM in reply to: Jeff_M
    Hey Jeff thanks for your reply. I understand that autodesk designed the points to change elevation when snapped to other objects, but is there no other way to toggle this behavior on or off?
    *Expert Elite*
    12-19-2012 11:48 AM in reply to: dcanete
    No, this cannot be toggled. You could write a program to do it, or you could get it via a 3rd party program such as SincpacC3D. (This command is available in the unlicensed version..IOW, it's free)
    12-20-2012 07:25 AM in reply to: dcanete
    Try setting 'OSNAPZ' to 1. This should make the snap a 2D snap, not a 3D snap. The points should retain their original elevation. Set it back to 0 to restore it to 3D.
    PS- Oops, I noticed you tried OSNAPZ. I just tried it, and it let me move the point and snap to all kinds of objects without changing the Z. With OSNAPZ off, it assumes the elevation of whatever the snapped object is.
    Windows 7 64-bit
    HP Z600 8 Gig RAM
    Civil 3D 2011
    *Expert Elite*
    12-20-2012 07:47 AM in reply to: ccoles
    I think the point made was that with the move command you can use osnapz to ignore the z of the snapped object.  But if you just grab the point and drag it with the grip it will always assume the z of the object. (Apart from one release of C3D, if I read the discussion correctly.)
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
