• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    BombthePeasants
    Point Sorting Progress Bar always on
    205 Views, 7 Replies
    04-25-2012 07:09 AM
    Dear Sirs and/or Madams,
    I am experiencing a relatively new and maddening AutoCAD problem. If I manipulate any point, or select a point group, or perform ANY action involving points in my drawings, a "Sorting" progress bar appears in the lower left hand corner of the screen, and if it's a drawing with a substantial amount of point data, it can/will lock my computer up. This is driving me bonkers! Can someone explain to me what is going on, and help me find a solution?
    Thanks in advance,
    ERIK
    attached herein is an image of the progress bar.
    Please use plain text.
    sboon
    Re: Point Sorting Progress Bar always on
    04-25-2012 08:21 AM in reply to: BombthePeasants
    Do you have any surfaces or corridors on Auto-Rebuild?
    Member
    BombthePeasants
    04-25-2012 08:41 AM in reply to: BombthePeasants
    I do, and have always had them in the past, but this is a new problem, as in only about 2 weeks ago.
    sboon
    04-25-2012 10:31 AM in reply to: BombthePeasants
    I believe that the sorting message refers to the TIN points within a surface.  The software needs to sort them as part of the surface build process.  Normally the operation is so fast that you never see this message, unless it's a very large surface.  I usually see it with Lidar datasets.
    watersam
    04-25-2012 11:19 AM in reply to: sboon
    This same problem frequently occurs in drawings where my points are not included in a TIN.  I am also going bonkers.  It seems to be a recent problem for me as well.  Is there a point setting that can eliminate the constant sorting?
    Sam
    sboon
    04-25-2012 11:35 AM in reply to: watersam
    The points being sorted are not your cogo points in the drawing.  They are the TIN points which are within the surface.
    watersam
    04-25-2012 11:45 AM in reply to: sboon
    I have a drawing with absolutely nothing but the points I just imported in it.  There's a lot of sorting going on.  Seems that getting out of Toolspace stopped the problem, but that's an issue for anyone who does have a surface in their drawing.
    New Member
    04-27-2012 02:07 PM in reply to: BombthePeasants
    Was having the same issue, so from the Prospector Toolspace, right click on POINTS, then select "Refresh", I have not had an issue since.
    Hope this helps.
    Rich
