• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    bo.martin
    Point Number Issues in C3D 2013
    194 Views, 4 Replies
    10-11-2012 11:31 AM
    Argh!!!!!!
    It doesn't matter where you set the Next Point Idenity
    In the Create Points dialog Box or The Command Settings
    Choose Create Points Interpolate and it resets to the lowest point number avaliable.
    Or.....
    Renumber some points that got entered wrong (From above problem)
    now try to create a point manualy
    the numbers already exist so instead of renumbering automaticly all you get is NOTHING!!!
    You have to reset the next point number. And if you enter a number that exist all it tells you is
    "Point Number Must be Unique"
    AUTODESK FIX THIS PLEASE!!!!!
    As if there aren't enough time wasters built in :-)
    Please use plain text.
    *Expert Elite*
    BrianHailey
    Re: Point Number Issues in C3D 2013
    10-11-2012 01:51 PM in reply to: bo.martin
    Did you submit this to Autodesk support?
    Valued Contributor
    bo.martin
    10-11-2012 03:35 PM in reply to: bo.martin
    Look all over.
    Can't find a place to email Autodesk.
    *Expert Elite*
    10-11-2012 03:44 PM in reply to: bo.martin
    I think THIS is the same issue, which Autodesk is aware of.
    Jeff_M, also a frequent Swamper
    Valued Contributor
    bo.martin
    10-11-2012 03:53 PM in reply to: bo.martin
    Thats it exactly!!
