Civil 3D Forum
Point Lag
6 REPLIES 6
kgrover
2422 Views, 6 Replies
Point Lag
I am running 64 bit Civil3D 2011 (Sp1)  and I get a cursor lag when I pan over a cogo point. The curser pauses for about 1-2 seconds and my processor spikes when I do this in the resource monitor.
I thought it may be the contextual tab states in the ribbon for points, but this didn't seem to matter.
Is there another setting for why it does this??
Kevin
6 REPLIES 6
C3D_User
in reply to: kgrover
Go to Settings Tab>Points right mouse click "Edit Feature settings">Expand General, turn off "Show Tool Tips".  That should do it.
K
johnsm
in reply to: C3D_User
I am having the same problem and that did not seem to solve it - any more suggestions?
JessieQuilatan
in reply to: johnsm
johnsm-
See this article: AutoCAD 2012 Performance Slowdown Hotfix
Michael Merlino
Civil Engineering Technician / "CAD Manager"
SAN JOSE, CA, USA
Sinc
in reply to: johnsm
Are you seeing a slowdown when panning over the points, or when selecting the points?
There's another problem that will cause a noticeable lag if you have the Properties palette open when you select Cogo Points.  It can be docked and set to auto-hide, and you'll still see the slowdown.  The slowdown goes away if you close the Properties palette.
Sinc
johnsm
in reply to: Sinc
the problem occurs just when I move my cursor over a point.  There is a point during the cursor movement where it "catches" for a couple seconds and then continues on.  It is not a big deal just irritating more than any thing.
Libaax5
Hi, could you kindly give detail steps, which setting tab, in windows or in Autocad 2011, can you point what where, I have freezing mouse cursor and it drives me crazy, it freezes every few seconds for 1~2 seconds, all hardware accelerator and drivers is updated, but freeze still exist.
Thanks Alex
Rail Community
